I might sell my soul for Prosport Peak and Hold gauges
Prosport Gauges
Prosport, Inc.
Jul 20, 2007
70
Tampa, Fl
www.prosportgauges.com
Check these out...we just got them in, a 52mm pod/Din panel snap in switch panel or fill an empty hole for those of you with a three hole pod and only 2 gauges. You can even mount an external warning light in there. Let me know what you think.
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
LOL@Panic button! hahaha
I like it Glenn... I see alot of those pillar pods with no gauge in one of the holes and you can see the inside, it looks tacky... That would be a nice way to plug it up till you get the gauge you need... I may get ont to plug the hole where my WIDEBAND will go until I get it... :D:D:D *hint hint* When that wideband comes in... *hint* you know when PS makes that kick ass wideband for us... ;) *hint* lol...
mk3forme
Lexington KY
Well I finally got my gauges hooked up and in my three pillar pod. I like the guages and all but the problem I was expecting is not the problem at all. I can see the numbers back lit and all fine, even with the targa out. The problem is I can't see the needle at all. I have to hold my hand over top of the guage to block the light so I can see where the needle is. That stinks. Also a recommendation for future production. The link wire that ties the guages together need to be about 2-3 inches longer. I was hoping to use these to tie my boost and EGT together to save on connections. But in the three pillar pod the gauges are spaces farther apart then the daisy chain will allow.
5
did you use the little hoods that come with the gauges?
steven89
892
Houston, TX
Have yall gotten Amber/white premium Oil pressure Gauges in stock yet? Mines still on backorder i think :D
Oh and is daisy chaining possible with Premium Amber/White Oil pressure, Water temp and a Regular Amber/white volt meter?
Do i just tie them all together and tie one end to a power outlet?
OneJoeZee
Retired Post Whore
aboard the Argama
I think I might pick up a couple of these. I want to expand my existing Defi setup but they are considerably more expensive. I think I will buy a few prosports for the time being and change them out when I get more cash to throw around for more Defis.
I really like my Defi system and all the functions it has. I do not want to get rid of it but I really need an egt, oil pressure and temp gauge right now.
I have a question about the oil gauge adapter. Does the one sandwich plate do oil pressure and temp?
Mk3runner
2,033
Nor Cal
I really like my Defi system and do not want to get rid of it.
weren't you the one the stood strong behind your defi gauges? maybe I miss read but I coulda swore.
