I might sell my soul for Prosport Peak and Hold gauges
mk3forme
Lexington KY
bwest said:
What? Rewire another LED? Why?
Just build a relay system that swaps power from wire to wire (lights on/off) based on imput (KO or lights on).
did you build a relay system like you talked about here? If so how about some instructions for the electrical illiterate like myself?:naughty:
bwest
Drafting, not tailgating
May 18, 2005
502
HippieTown, CA
no, I just followed the instructions :)
red and white to power, orange to the interior lights. The blue gauges don't have this option.
The wiring is simpler that how I interpreted it based on the descriptions earlier in the thread.
BRIAN
187
socal
bump
I'd like to hear a bit more about the accuracy of these gauges if anyone wants to share please.
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
I just got mine this afternoon :)
Day time (I know they're crooked, it's fixed now):
Night time (with flash, sorry):
I notice that the boost gauge is off about 4psi on my car. With the car off, it reads like -7mm/hg or so, and at full boost (16psi) it hits 12psi. It kind of bugs me. The EGT and Oil pressure seem good though.
Every time I turn the car off, the damn oil pressure starts flashing and beeping because of the zero oil pressure. I tried muting it, but it lost the setting as soon as I restarted.
I like the gauges though, nice quality.
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
Rob, your steering wheel is on the wrong side... ;)
I like how you mounted your guages... As for that boost guage, sometimes in shipping, they get bumped and that knocks off the accuracy, it just needs to be zero'd in again... My old Autometer was like that, but they just had me send it back to them and gave me a new one...
annoyingrob
Boosted member
Jul 5, 2006
2,304
Actually the steering wheel is on the RIGHT side. hahaha.
I'll email them about the boost gauge being off. Hell, maybe I can open it up, and adjust it myself. I didn't check.
DaemoN
205
Wichita, Kansas
www.TeamFE.net
Mine is a little over 1psi off... if you find a way to adjust it yourself please post up!
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
no if the car is off and its not at 0 then that means the gauge is off...
bwest: you got one of those pimp 120$ holders off ebay didn't you? powdercoated aluminum right??? how is the visibility i was looking at em and found em on accident and they look sick but wasn't sure on visibility
annoyingrob
Boosted member
Jul 5, 2006
2,304
mk3forme said:
Thanks for the pics Rob. How do you guys know your guages are off? What are you comparing them too? Your old guage readings?
I have a Profec B spec 2 which I know has an accurate pressure gauge. I compare it to that.
I would assume the gauge comes with a 3bar sensor, as it reads up to 30psi, so I'm going to compare the output of the pressure sensor on the gauge with the 3bar sensor I have on my ECU, and see if the sensor's off, or teh gauge itself is off.
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
These are electric right? Are the readings inaccurate when the car is completely shut down (not returning to the bottom) or when the car is powered? You may want to check your wiring (compare the gauges 12v to the alt and the ground to the block).
annoyingrob
Boosted member
Jul 5, 2006
2,304
Yes, they're electronic. The gauge needle when started does a full and proper sweep.
I emailed them, and they told me to send the pressure sensor back.
