Kemosabe;1063084 said:I guess the one thing missing here is whether the original author of this thread has removed the precat and replaced it with a downpipe. That was the single most heat reduction for me.
adampecush;1062567 said:have you verified the operation of the thermostat? It sounds like it is either stuck open, or improperly installed. You're not using the mocal ot2 thermostat by any chance are you (there was a design change, thus there are two different sets of install instructions....pm me if you want more info)
john93t;1060643 said:remove the rubber seal between the bulkhead and hood
IJ.;1061186 said:ALL front plastics in place including the shroud and the car does the rest.
MaJiKaL TaNk;1063501 said:I was thinking about doing this but my cars body is in great shape and I don't want the heat to start messing with my paint. I just want to keep the original paint as long as possible. Will removing the rubber seal let the heat to my paint too much? Sorry if a dumb question but I was just wondering.
americanjebus;1063726 said:I stand by this and everyone who says to keep the undercover, its a HUGE difference.
I blew a small radiator hose that emptied my entire coolant supply, ALL of it trickled out the bottom so there was no smoke or indication that it was being emptied other than the coolant light. I was on the highway on a 90+ degree day and noticed the coolant light, i made it 40 miles on the highway to the nearest town and the temp didnt flinch, and yes it works. When i pulled over and had it idling to look for the leek the temp gauge finally twitched upward a couple millimeters.
americanjebus;1063726 said:Ps. I also have removed the rubber strip behind the hood for over 3 years now and havent felt the ill effects even in the carwash, so i dunno i guess i'm just getting lucky. I pop the hood and the engine is dry, meh.
	suprafredde;1064049 said:Someone on this forum or at SF actually meassured pressure on a few different spots on the supra while driving. Showed that its not working to raise the hood or remove the rubber because thats a high pressure zone and you get air entering the bay not exiting and then the air has to go out under the car creating lift...
theWeezL;1064202 said:Exactly why a cowl induction hood works. Due to the pressure differential it draws in cool air when the vehicle is in motion. When the vehicle is stationary, it will vent hot air as that is the highest point of the engine compartment (heat rises up and out). When I was driving at speed on a rainy day I could see the rain drops being sucked in the back of my cowl. When I would come to a stop I could see the heat waves billowing out the back.
IJ.;1061731 said:Pics of the liner?
If I remember correctly a small scoop facing the windshield just above the coilpack, or ducts behind the front wheel like the c4 vette proved to be the best for lower temps.
(with the plastic undercover in place)
suprafredde
	jetjock;1064669 said:Fwiw the Body Electrical Manual (which covers the climate system in detail) shows pressure distribution vectors on the car. The base of the hood/windshield is quite a bit positive. One reason the fresh air inlets are there...
