suprahilux;1553150 said:Not sure if I will do that b/c the intake temps may be lower running all the boost from the turbo when it kicks in.
You could use water methanol...:naughty:
WOW now I'm bagging ideas without saying so...... :nono:suprahilux;1554432 said:Well, 450hp goes a long way on 2800lbs, hopefully 2600. But you're right, once I am there I may want more.
For setup, I meant complicated as how to mount the jet to spray the air stream evenly across all the cylinders. The kit comes with only one jet. Maybe my manifold is what makes it complicated.
For now, I should not need it at 20psi max. If I was running more than 10psi from the sc, then I would use it for sure.
I was hoping IJ would chime in here with some of his wisdom. He probably just wants to say I am wasting time with the sc and it won't give me much gain, it will be more trouble than it is worth. Or I should have just gone 1uz tt. Or maybe not... his absence is a loss.
zambini;1555067 said:damn this project is serious!
but.. mustang lights??
supra90turbo;1555855 said:07+ Tacoma tails are LED and would look goooood.
Maybe it's 09+...
