suprahero;1056085 said:17psi w/ gt35r and 1.5jz
How does that spool up ? Whats ur Hotsides A/R ?
slidingsidewayz;1067792 said:does anyone know what the max boost i can run on 440s with a to4 turbo? i'm hoping to hit 18psi, but i don't know if im going to be maxing out my injectors or not.
sc250tt;1065797 said:Its been at 20 psi for almost 2 years and still no smoke . Im running a hks evc and a hks fcd on stock fuel with the exception of a supra tt pump and 12v mod.They loose effiency after about 120 mph or so .I am automatic with a stock dp thats probably one of the reasons they haven start screaming and smoking yet .
Boost Lee;1075818 said:Actually...
If you're running a stock downpipe, with 20psi...
This would be more likely to cause failing turbos.
When you're running that much boost, restriction is the last thing you want.
(ie. Running a 7M at 20psi on a CT26 with a stock exhaust).
You're choking up those turbos when they really need something well-flowing enough to let out all those exhaust gases.
Very gutsy, though.Got any numbers?
Jeff
It is really funny how often this argument comes up.sc250tt;1076809 said:Actually if those ceramic babies spins more than it is doing right now they have a greater chance of disintegrating. I have a 3 inch exhaust split to 2 1/2 in the rear with no cats or resonator so im still getting most of the back pressure out at a decent rate ,the other thing that puzzles me is everyone i know with a downpipe blown their twins .I don't have any numbers but when i do get some i will definitely post it up .
wow, you can really kick that puppy up. I want to see what 18+ will do. :icon_biggnamkiii;1077322 said:i run 14 with the ct kit from driftmotion
Wait a minute, did i just read 7m??? I thought this was the other engine tech section.:biglaugh:Van;1077339 said:12 PSIG on CT26 w/following mods: Forge adjustable wastegate actuator, 7MGTE w/HK$ stopper head gasket and ARP head bolts, APEXi intake, Cooleze turbo inlet pipe, LIPP 2.5" hard pipe kit, LIPP SS 3" turbo elbow, RT 3" downpipe, 3" RT Cat, 3" exhaust and muffler. Van
viperkillertt;1077042 said:It is really funny how often this argument comes up.![]()
viperkillertt;1078275 said:what turbos? Stock twins????
Ok, most people have been posting the turbos with their pressure. I never check peoples profiles. Sorry.10secdream;1078319 said:His profile says GT4088
Haha, no worriessuprakid24;1078738 said:yea, I guess I could have posted the turbo, and I also didn't read where this thread was because i'm 7m
ooops
