How much boost PSI are you running?
SPD TRP
Formerly 3rdtimearound
Apr 12, 2005
526
Katy Texas
annoyingrob;1054818 said:
Hits 18psi at 3800rpm on the 1.5JZ. Was doing about 4600rpm on the 1JZ. That's with 272 cams, and a .81 hot side.
Thanks for the info, since mine is a 1jz, I think I will stick to the gt3582r.
Wayne
SPD TRP
Apr 12, 2005
526
Katy Texas
jza71;1055227 said:
35psi on stock long block and still feel the need for more:evil2:
Just went and looked at your youtube video, what turbo are you running and how about some dyno sheets. Would like to see the spool characteristics.
Wayne
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
Wayne
from what i remember i think he is using the pt71 but i'm not sure if its the hps
Boost Lee
Bee Doo Bee Doo Bee Doo
2,750
Indianapolis, IN
sc250tt;1054108 said:
20 pis on stock twins:evil2:
And how does this work out for you?
As in, can you feel the twins wanting to die off at higher rpms with 20psi?
What EMS are you running? Or are you simply using a FCD of some sort?
Jeff
87soup
F*CK SMOG CHECKS!!!
Jan 23, 2006
864
Sacramento
I have Down Pipe, Intercooler, intake, Y-Pipe, and i barley hiy 10psi:(... What could be wrong?!?!??!
I also hit feul cut with a boost controller hooked up at any setting:cry:
sean210
Father to Be
Nov 26, 2007
315
indianapolis
Ok I here people saying 1bar and then others saying a setain number of
boost whats different in the way the two gauges read?
Im a noob and I am curious.
sc250tt
twins @20 psi
Mar 22, 2007
10
florida
Jeff
Its been at 20 psi for almost 2 years and still no smoke . Im running a hks evc and a hks fcd on stock fuel with the exception of a supra tt pump and 12v mod.They loose effiency after about 120 mph or so .I am automatic with a stock dp thats probably one of the reasons they haven start screaming and smoking yet .
