How have you improved your car since you've owned it?
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Man, old ass thread revival. Anyways, bought the car bone stock, except came with a fucked up passenger side, probably from the kid owning it before trying to drift with it :3d_frown:. Mods are in the profile, but a lot of them aren't installed.
Here's what's pretty much on it now:
Cooleeze DP (coated and wrapped), test pipe
RSR-GTII exhaust
2.5: DIY hardpipes w/HKS SSQV
Bigger spearco style IC
Replaced most vacuum hoses
intake kit w/SS air filter (don't buy one)
GReddy shift knob (came on car)
Stock CT-26 at unknown boost, probably about 8.5-9.5 psi straight off the unshimmed wastegate. Boost gauge pegs now with the hard pipes and IC installed.
Modified GReddy catch can
OBX coolant resivoir
NeatOman
Never know enough!
Oct 5, 2006
233
Addison, IL
Interior swap, didn't have rims, did not run of course.
Basically what you need to do to a car when you buy it from a junkyard.
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
Reign_Maker said:
Well when I first bought it, the car ran fine...
Now, there's no motor in it... I guess you could say at this point, I've made it worse...
One year later:
OneJArpus
2,798
Car #1 - 1989 Toyota Supra Turbo Auto
- New Radiator
- Rebuilt LSD
- New hoses
- New Vac Hoses
- tune up
- New calipers all around w/brakes & rotors
- New intake (apexi)
- New front seal for targa
Car # 2 88 Turbo 5SP
- 1JZ Motor
- FMIC & Pipes
- ACT PP & Clutch Setup
- KevinM Sun Shade
- JDM Side markers
- Hella H4 Headlights
- Euro Turn Signals
- New calipers
- New Brakes
- New rotors
- Coilovers
- New Koyo Radiator
- New Speedo Cables
- Fixed gas door
- New intake w/ pipe
- Y-Pipe & Downpipe
- Testpipe
- Earls brake lines
- SS Clutch line
- New vac lines
- new hoses
- T stat
and more to come
sway bars
wheels
running =P
Both cars yeild over 10K easy :( not sad at whati put into them :) i love both of them
2543arvin
Moving to Japan!!!
Nov 30, 2006
879
Jacksonville, NC
Reign_Maker said:
One year later:
That is so badass having your screen name on your 7M. Im jealous....
Anyways, stuff improved on my supra:
Pulled n/a motor, swapped gte motor in
pulled motor again, rebuild time
forged internals
new hoses
new turbo
fmic w/ hardpipes
six puck ceramic clutch
swapped cloth interior out, put leather in
mkiv wheels
hks ssqv bov
balanced and blueprinted, yada yada yada.....
Oh yeah, and REMOVED the gay ass skull shift knob, that the previous owner installed.
whudafux
Formerly dcrusupra
Jan 5, 2006
1,034
Cullowhee, NC
Wow, I had a post from my last Supra in here, lol.
Anyway, I bought the new one with a blown head gasket and a cracked bellhousing. So I bought a new 7M-GTE and tranny and put that in. New 2.5" IC piping, a new battery, new alternator, new rear window, 4 new tires, and a new master cylinder.
BJ91T
810
Baton Rouge LA
When I found the car It had been parked for 3 years and the owners told me "we just parked it because we bought a new car......WRONG I'll bet they parked it due to the BHG and two spun rod bearings.
Since purchase
*Fully Rebuilt motor
*Newer Interior
*new stereo
*new rims,tires,brakes
*Spent 4 days removing tree sap (still has some)
*About to get repainted
SupaMan
Want The Boooooossttttttt
Oct 12, 2006
1,101
Cape Coral,Florida
since i bought it ive done the normal maintenance and checks oil,brakes,ect I planned to get an alignment just incase and it turned out the car tracks very straight it doesnt pull at all, Ive fixed very questionble wiring jobs with the antenna and stereo ive replaced a couple rusted panels and the the weatherstripping for the hatch, ive also ruined a perfectly good set of rear kuhmos :)
lots more in the future tho.
next thing on the list is that ugly steering wheel.
grsupra87
Let's go Pens!!
I got the car a little over 2 years ago. Its an 87. When I first got it I did the usual change gaskets/belts/hoses/plugs/rotor/cap thing. In addition I've:
*replaced mudgaurds
*replaced moldings with 89+
*replaced both front fenders
*painted the car
*replaced wing that was on it (91 firebird) with correct wing
*replaced e-brake boot
*replaced coin tray with a working one!
*added FIPK
*3" stainless custom pipe cat-back
*Ractive muffler
*tinted back three windows
*replaced mucky drivers side taillight
*replaced rotors with drilled/slotted
*I.C.E.
200Watt pioneer head
2 600 watt pioneer 4 ch amps
2 220 watt 4" door speakers
3 MTX 10" subs
4 Pioneer 400 watt tri-axles
I know it's alot of little stuff, but my car is always getting better.
Now I just want some nice rims!!!
new used engine, rebuilt head, new wiring harness, new CPS, new clutch, HID's, whiteline swaybars, tires, bosche icon wipers (expensive enough to be considered an upgrade), downpipe, water pump, fan clutch, fan shroud, koyo radiator, samco hoses, ect ect ect...
the dealer loves me, and I've spent over $3K over the price of the car...but she starts up and drives EVERYDAY.
see sig... VV
NewWestSupras
SoupLvr
Mar 1, 2006
611
White Rock
'88T, bought with a spun rod bearing. Rebuilt engine, new clutch, springs, shocks, brakelines, lower ball joints, rad, turbo, exhaust, shifter. To go in still: Maft, ffim, new i/c, buncha other small crap, lastly paint, body, bigbrakes and audio.
johnathan1
Supra =
Aug 19, 2005
5,056
BorHor said:
Way to much.
Damn you! I was just going to say that...LOL.
I have put a TON of effort and work into my Supra...most was just getting it back to stock and somewhat reliable...it seemed like just about every part on the car either worn out or broken (some things still are)...
I also think it's quite interesting that my diesel benz is 5 years older, has about the same mileage, and was sitting for 10 years outside in dusty, hot central california...and all it needed was to be started and driven...seriously...all I have done is replaced the brake pads, and tires, and drove it over 100 miles on the freeway with absolutely NO problems...hmm...I wonder what that means?? :icon_conf
