Okay so it is time for another update. I have been very busy working and trying to get my car done with limited work space outside but inside I am able to finish wrapping it up
Since the last time I have bolted down the head with ARP's, installed the intake system, injectors, wiring harness, all the small accessories minus the alternator (mines is dirty so I might need to buy a new one haha)
Main thing that is left is welding the flange for my wastegate and then I can finally bolt on the manifold for good. Rear main seal, oil pan & such will be bolted and siliconed once on the engine hoist.
I still need to do some wiring cleanup and hiding so it does not look as scary but it's coming along, Im HOPING to have it up and running in the car sometime next month if not earlier.
Here are the pics thus far
The fuel system preview
External pump, -8an fuel line to the firewall then -6an to the rail and stock return. Also running an AFPR at the front to help tune the pressure right. Injectors are 560cc's so plenty for the mid 400hp range
For the clutch i am running a stock set up but with an ACT 6 puck disc.. I like the stock feel of the clutch. Also putting ARP's behind the flywheel for added strength.
Tuning will be done using a MAPECU (hint for the HKS horn, only for special occasions and show) and AEM wideband. Glad to get rid of the stock AFM! Turbo is, well it's big I measured roughly 72mm :naughty:
Once I get the stock motor out and I can start cleaning the the engine bay and get that prep'd and I have been thinking to maybe paint the car FIRST or should I wait until the motor is tuned and running? Tips from experienced builders would be great
