like title says...i just replace my head and headgasket, cranks but no start....cranks freely like no combustion happening...fuel pressure is at 25-30 psi key on....has spark but looks weak....any clues would help
kotu100;1300770 said:your timing is off.
make sure you crank and cam gear timing marks are line up.
and if you took the cam gears off make sure both the pins are in the middle holes on both the gear and the shaft itself.
i recheck timing and timing marks are all lined upkotu100;1300770 said:your timing is off.
i know you can use a paper clip to jump the thingy but do you know the exact pin to jump?dbsupra90;1300735 said:holy crap that could be anything.
check codes of course.
first thing i would look at (aside from goofy things like plug wires in wrong order, something not plugged in, etc) is make sure the cps is aligned properly. it's real easy to align it wrong.
kotu100;1301545 said:i even did the google work for ya
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/default.aspx
do everyone a favor and read, if you still have questions regarding specifics, feel free to ask.
how did you set your CPS
Skadaloz;1301547 said:ahah i just search after i posted and found it...and as for the cps i put it back to the same position b4 i took it off(i marked it)
cranks a little faster than normal but nothing happensmkiiSupraMan18;1301554 said:No combustion meaning.... not 'trying to start' but turning over or 'its turning really fast and nothing is happening'
i dont think it was...i wonder if i did my timing wrong, meaning #1 piston at TDC but on power stroke instead of intake stroke? would it even matterrayall01;1301592 said:When you marked it, was the #1 piston at compression TDC?
mkiiSupraMan18;1302224 said:^ would backfire like a mo-fo, you'd know if that was the case.
adampecush;1302264 said:i don't care how much you "marked" the cps position. Did you re-install it as per the TSRM specs? If not, re-adjust and get back to us if your problem persists.
Skadaloz;1302284 said:ill get bak to you on that
well anywais i just check my check engine light and this is wat i got
blink..blink.....blink..blink.....blink..blink.....blink..blink..blink..blink and repeat
so is it code 22 and 24?
dbsupra90;1303042 said:22 = water temp sensor. either not plugged in correctly or the sensor is bad. wouldnt cause the car not to start.
24 = intake air temp sensor. you running the stock afm?
7mgte1988;1303136 said:I might be wrong but i hade this same problem 2 months ago but mine was the wires from the CPS. i had to wiggled the wires and have someone start the car and it will turn over.
