help, no start after replacing HG
Skadaloz
32
Ephrata,PA
adampecush;1303601 said:
Why would you even be trying to have us diagnose your car without having simple stuff like that fixed first?
I'm going to start giving half-assed answers as it seems most looking for support tend to half-ass their own work.
it still plugs in fine...if i had another connector of the same one i would swap it but i dont
Skadaloz
32
Ephrata,PA
well just did a compression test and theres no compression...what would cause a no compression but the motor ran fine b4 i took the head off???:icon_mad:...but aniwais i decided to do a cylinder leak down test...and there 100% fine...no leaks at all on all cylinder...wtf is up with dis motor
7mgte1988
7M-Runner
Sep 22, 2008
223
Orlando
Sound like something isnt getting power. is this a gte or ge??
Did u turn the crankshaft a little after u put the head on cuz that would say a lot about your timing.
Skadaloz
32
Ephrata,PA
its a 7mgte...but my timing is right on...i even set the cam gears to TDC and remove the timing belt and turn the crankshaft to tdc then put the belt back on and still no start and no compression
Skadaloz
32
Ephrata,PA
well i redid the compression test and no compression(dry or wet) so i redid the cylinder leak down test and what did you know...all the freakin intake valves are leaking bad like 95%...b4 i put the head back on i did the valve lapping all all valves...guess ill have to do a valve job or just swap the motor out w/ the 1jz:icon_mad::icon_mad::icon_mad::icon_mad::icon_mad::icon_mad::icon_mad:
gtsfirefighter
SM Expert on White trash
Sep 26, 2006
2,965
For some reason that just seems very odd to me. You must've either really screwed up the valves or something is still not lined up. Seriously, double check to make sure your cam gears are on correctly. When you put them on was there a dowel pin there to line them up correctly?
Skadaloz
32
Ephrata,PA
yes there on correctly but ill double check it...i even turn the crank 360 degree while i have the cylinder leak down tester on pushing 100psi of air into the cylinder and it still leaks
