Help: JDM 7MGE Swap
RallySoob
Rally Man Sam
Nov 2, 2006
83
Oregon
Im puting a JDM 7MGE in my 86.5 Supra Targa Sport 'Tomarrow' and was wondering if any1 knew what conversion issues I might run into... The engine is from an automatic and Im not sure of the year of car it came out of but I am going to assume its out of a 90 or 91 and maybe even an 89. Using my W58 too. So ANY and all help is needed, maybe just a link to another thread...? I can't find anything on this conversion, probably because its pointless to 99% of peeps, but it's going to rally one day soon and I gotta roll with this motor for many different reasons associated with that :1zhelp:
**Update**
Video of startup with a suspected knocking sound
http://www.youtube.com/watch?v=JPPzkmPABxU
Engine Installed, heres pix from the project so far. Sorry but i forgot my camera so i used my cellphone
In transpost
kool Shot i guess for a cell phone
clutch is toast
the newer 26,000 mile:icon_conf motor with new clutch on
Manuevering through the JDM BS
Cressida vs. Supra oil pans
new pump
pump goin in
layin the Black Bead of goodness
Its In!
Almost Done
These pix are as of 2 nites ago, It's runnin now with a possible injector seal leak?? fixing it tonite and tuning throughout the weekend... wish me luck
1988SupraDreams
509
San Jose, CA
Flywheel has to be swapped (Duh) The engine's gonna come with EGR block off plates, and if you want the car to be smog legal, you're gonna have to swap an EGR onto it, EGR VSV, a BVSV and a USDM Throttle Body. And if the engine is an 89+, You're going to have to swap motor mount brackets to make them mate up with your 86.5's square mounts, and you're gonna need an 89+ Nonturbo M/T Harness and ECU. And also while the engine is out, change the HG, or at least retorque it.
Hope that helps.
ubara86
24
LA
Its all quite simple, look at your old motor now look at the new one, make the new one look exactly like your old one.
Koenigturbo
1,338
Oxnard CA
I have some gte parts
Junior
143
Ontario, Canada
when I did mind I ended up swapping the upper intake and throttle body over to deal with the vacuum issues, bypassed the EGR, remember that your coolant lines will be backwards as the JDM motor is RHD, make sure the oil pan is the same, often they'll advertise it as a supra motor, but it actually came out of a cressida. If you miss it you'll have big problems seating the motor in the crossmember :)
btw, "tomarrow" is actually spelled tomorrow, unless you did that on purpose.
RallySoob
Rally Man Sam
Nov 2, 2006
83
Oregon
hmm... all this is gonna help. Last night we got the engine out, now we need to get the two engines next to eachother and compare. I Will do that tonite and I will take a some Pics of the motor(s) so you Supra Gurus can put the smack down on this project! Thanks Again, the support is good here....
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
My recommendation would be to compare the oil pans first. Then start taking pictures, of the coolant hose routing, the vacuum routing and wiring. Keep taking as you go deeper. This will help if you end up have to mix and match parts.
Junior's right, if you are planning on keeping it smog legal you'll need to keep the original upper intake manifold, "Y" pipe, throttle body, etc.
The coolant lines don't have to go on backward. I can't recall if the JDM engines have a different hardpipe assembly which wraps around the block, but if it is, just put on the one from the old engine and stick with the stock hose routing.
Junior
143
Ontario, Canada
supramacist said:
well junior...., mind is spelled mine, unless YOU did it on purpose.
LMAO, fair point. Brain appears to not be entirely connected today.
I only mentioned it 'cause it's a super common one, my little brother spells it tomarrow to this day.
supra-addiction
111
hampton
CRE said:
What about it? Other than the fact that their data is all wrong. The 7M-GE is not a 1.6L 180HP engine.
yea thats my point! lol
IT'S ALL WRONG! AHAHAHAHAHAH!:biglaugh:
IT MADE ME LOOK TWICE
I WAS LIKE "what the freak"
let me show this to my supra buddies..
supramacist
1,501
The Grassy Knole
Right on..., way to be a good sport is all. We all do it and I am one of the worst.
