Heat Heat
xms
269
tx
Ric said:
radiatorbarn sells stock replacements for under $200. They are copper/brass construction which is better then aluminum.
Aluminum is only better then a copper/brass radiator cause it looks better and lighter. Brass/Copper is proven to cool better. My 3 row radiator costed me $180 shipped. Factory is 2.
do you have to ask for a 3 row cuz it's not on the site
now Koyo, new waterpump, new fan shroud (my old one wasn't that bad, but I wanted to be sure), new fan clutch, new radiator cap, new t-stat, samco hoses and toyota red coolant
doesn't EVER get over 1/3 up the gauge, usually around 1/4 up the gauge.
no engine undertray (it's not as critical as everyone says, what IS critical is the side parts that funnel the air into the radiator and the fan shroud)
I can't run any cooler than I already am (you can tell when the t-stat opens)
I'd run an undercover myself, but it's too expensive for something that's gonna get ripped up...
might make a custom one that funnels the air fromt he front grill into the intercooler and the rest of the cooling system...
but overall, those other components are far more critical (especially the fan clutch! I probably could have replaced just that and been fine...)
are you calling me slow? LOL
we all can't spend bookoo bucks like you (you have more in your engine management than I have in my whole car (not including purchase))
LOL nah not slow as such but I see things a little differently than most ;)
For me e-fans have always been a last resort on swaps where I couldn't fit an engine fan as they just don't make sense for all of the above reasons.
xms
269
tx
I just called radiatorbarn and it's the same stock replacement that in my car???
CarlosPTR210
435
Calexico,CA
www.ptr.com.mx
Here is also hot: Imperial, CA,
With out AC system on:
Ambient temperature 12pm – 5pm: 100 - 115F
Water temp: 190 – 200 F
Oil temperature: 190F
I have the following cooling mod's:
Koyo Radiator
New fan shroud
180 Thermostats
Redline water additive
Permacoll Oil cooler with electric fan
New water pump
New Fan clush
MR2 Hood vent
xms
269
tx
Koyo Radiator
New fan shroud
180 Thermostats
New water pump
New Fan clush
MR2 Hood vent
so which model koyo radiator do you have,cuz the one that i have been seeing around are for the jz setup
mkIIIman089
Ohio
So, really what you're saying is that you don't have the slightest clue what temp you are running. I have seen anything from 88C to 110C on my GReddy gauge and the stocker has moved so little its barely perceptible.
I run cooler than others with the stock gauge...
not like it matters as you WILL have fluctuations in temps, it's completely normal...
yes, in the area it sits now, it's actually very linier
I can see fluctuations if I get in hot situations, but it never even gets to half now (which is where it "stops" and then once you really overheat will jump)
Larry_A
You don't matter
Apr 7, 2005
102
SoCAL
Poodles said:
.....doesn't EVER get over 1/3 up the gauge, usually around 1/4 up the gauge.
Referencing the OEM gauge is next to worthless, like a narrow-band O2 gauge, but you already knew that.
The under-cover is a significant component of the car, maybe not so much in cooling, but in overall aerodynamics...specifically & clearly mentioned in my original sales brochure for the car. Also, without the cover, small bits of gravel/rock/flotsam-jetsam get into the accessory belts, chewing up both belts & pulley ribs. I've seen severe pulley rib wear on many non-under-covered MkIIIs, while pointing out the bits of gravel stuck in the belts to their owners. So people should really reconsider its importance if you've shrugged it off due to cost.
