From what I understand, a connecting rod is put to it's greatest test under tensile loads and not compressive force. Does anyone know which connecting rod design, H-beam or I-beam, performs best under said conditions?
Supadeviljuice;1085299 said:From what I understand, a connecting rod is put to it's greatest test under tensile loads and not compressive force. Does anyone know which connecting rod design, H-beam or I-beam, performs best under said conditions?
osofast7m;1085374 said:be sure to get connecting rod bolts with at least 190K of tensile strength otherwise you will always be prone to mechanical failure. Hope this helps and good luck!
Khris
GrimJack;1085727 said:Do you really want tougher bolts than rods? Wouldn't that make your point of failure be the rod itself, rather than a bolt?
I always try to set things up so that the cheapest part to replace fails first...
Come to think of it, I don't think so... I've seen lots of failed rods, but I can't recall seeing a failed rod bolt.adampecush;1085735 said:Have you ever seen or experienced a rod bolt failure? If you break a rod bolt, you certainly won't be re-using the rod.
Wow, that looks like something took the runner up prize in an axe fight.IJ.;1085745 said:
need new tires;1085766 said:![]()
-shane
