And it makes our balls not sweaty in the summer time after it cools down inside the car
Just thought I'd add that
I would stay away from the Freeze 12 if I were you. Freeze 12 is 80% R134A anyways, and has a lot of drawbacks. There is no reason to use it if you are flushing the system and putting PAG oil in. Most people use Freeze 12 when they are too lazy to flush the mineral oil out and want to convert without using PAG. The 20% R142B is put in it to carry mineral oil. You are much better off with R12, but if you must, R134A is going to be better than Freeze12.gurley0916;1732566 said:Thanks for the input Devin, The system will be filled with all r134a oil and if I am not happy with the freeze 12 then I can evacuate it and throw in r134a as they are both compatible with the PAG oil.
