Guess my Dyno #'s
Status
Not open for further replies.
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
Well guys... the good news.. I drove the car home.
The bad news.. 505 RWHP 497 RWTQ @... (here's the disappointing part) 29 PSI :(
I was having boost control problems.. I'd hit target boost but then it would fall off towards redline (as you will see when I post the chart).
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
Stock N/A cams.. Blitz SBCID boost controller.. I have a HKS Style wastegate with a 10 PSI spring...
I'm starting to think that my problem is trying to run so much boost on a 10 PSI spring.. can anyone confirm this as a problem?
Notice on the graph how I hit max power and then it immediately falls off so jaggedly as if the wastegate is fluttering..
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
exactly what I was thinking.. I'm also going to weld a dump valve into my downpipe for some extra power.
i was going to up the gain on the boost controller to see if I could get some higher #'s but a blew an IC pipe on the last run.
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
I'll have to go get my laptop later to tell you my timing #'s.. but judging by my dyno sheet I hit 29PSI at about 4.7K RPMS..
I'm also suspecting a boost leak (IC pipe has been working its way out for awhile until it blew today).
WeDgE
Buh-bye 7M...
Jan 2, 2006
495
Alberta
Your HP and TQ numbers are very close. Not something you normally see with a Supra engine making that much power...
RacerXJ220
Interdimensional
Abalama
Stock 2JGE cams do 700whp++, not an issue here.
What meth kit are you using? Is it a progressive kit? When did full spray hit?
Let's see those timing numbers.
GeneStarWindGSW
Been To The Other Side...
Mar 25, 2007
992
No Man's Land
www.bidmingle.com
My 2JGE mk3 is for sale. who ever wants to own it and beat scott, here's your chance ;). Scott its probably a small problem your overlooking. Like my friends compressor housing washer that came off once and his boost was leaking a by there.
Status
