Yea, the motor pulls/sounds/feels great. It's really not laggy until you put a lot of boost on it. There is pleanty of power in all gears but I havn't been able to take advantage of 1st or 2nd because of my 2nd gear synchro being shot.
hottscennessey said:Yea, the motor pulls/sounds/feels great. It's really not laggy until you put a lot of boost on it. There is pleanty of power in all gears but I havn't been able to take advantage of 1st or 2nd because of my 2nd gear synchro being shot.
well It stays in 2nd just fine, but I can't shift fast into 2nd.. I have to double-clutch to get it into 2nd.What exactly do you mean by "shot"?? It wont grip in 2nd gear... you can't snap 1st-2nd...???
IJ's right, it should be MUCH higher. I doubt holding boost to redline and revving it out would give me another 100+ WHP. IDK whats wrong
No matter what boost controller you have you can only "reliably" double what the wastegate spring is worth. Usually you can get just barely more than double what the spring is worth, IE a 10psi spring would/should only be good for 22 +/- psi. We have experienced this many times.hottscennessey said:Stock N/A cams.. Blitz SBCID boost controller.. I have a HKS Style wastegate with a 10 PSI spring...
I'm starting to think that my problem is trying to run so much boost on a 10 PSI spring.. can anyone confirm this as a problem?
Notice on the graph how I hit max power and then it immediately falls off so jaggedly as if the wastegate is fluttering..
You guys are overlooking it the benefit of latent heat of evaporization of water, and the effect cooling has on detonation suppression. Do what ever you want but I would mix Methanol and Water. You will get 1000 different opinions on the ratio, but for street use I have always used 50/50 but Im not anywhere near 29 psi. If I was doing dyno runs I would use race gas and H2o/Meth to make sure I was safe.hottscennessey said:I read on the scooby forums that meth was 129 octane?
Also with a 50/50 mix with 93 octane (using the appropriate nozzle size per calculator) snow performane techs was claiming 116 octane on their forum.. that one I'm not buying..
I KNOW that is one of your issues, if you have others I couldn't say. If you search the boards you will see this all over the place. If you think about how fast a WG has to react all the time that could definitely be the cause of that jagged graph. Remember if the WG opens no matter what the reason you WILL loose power.hottscennessey said:Thanks ARZ, that makes perfect sense.. a 1 bar spring it is! I'm still doubting I'll see great results just by swapping springs tho.. there's gotta be something else.. but does it look like the wastegate situation could be causing the jagged dyno graph?
OH, and I'll definately have race gas in the tank next time.
Agreed!!! Call the Dyno place and tell them YOU need to drive the car. And have a Camcorder running in the cockpit so you can see all the gauges and can play it back and watch it yourself. Also have a second camcorder going outside for your entertainment value. If they wont let you drive the car, tell them your going to find another dyno place. If you would have noticed that boost loss on the first pass you could have learned a bunch more from it. Also dont go to the dyno with the attitude "I gotta hit X HP!!!" that is a sure fire way to go home on a trailer.tissimo said:how many pulls? play with the timing on the dyno.. thats how you make power
According to my research water can be as much as 25% of the total amount of fuel, you have a long way to go before you loose power. It does evaporate and take away more heat, but it also consumes more thermal mass, (it makes the atmosphere more dense). What people forget is that fuels (methanol included) have very poor surface tension, when they are suspended in a vapor they avoid hot spots, embers, freshly ignited carbon deposits, even if they do make contact they have very little cooling effect. Water while suspended in a vapor does has a greater propensity for contacting items in the intake tract and combustion chamber due to its surface tension properties. This combined with the latent heat of evaporization, combine to actually quench hot spots not only in the combustion chamber, but also in the whole intake tract. The water vapor will continue to cool even after contact due to the velocities involved in the whole intake system. That being said, I have not researched the difference between straight Meth and H20/Meth, so check for yourself and go where the research leads you.tissimo said:As far as water goes.. imo it may evaporate and take away heat, but will make less power. For example on a high humidity day it will take away power. So why spray water in your engine? Plus the added octane from the extra methanol in the cyls will greatly increase the power and added knock suppression will to outweigh the heat absorbed though evaporation of the water.
I would only try this if you have a good reliable way of detecting knock and a way to shut it down quick. This right here, is the main reason I haven't experimented. And because Im cheap, 50/50 goes twice as far.tissimo said:Try back to back, I assume you will get greater power from straight meth.
Check on SF a guy logged his timing on a mkiv w/ an OBD 2 scan tool with 50/50 and straight meth. More timing from straight meth = less detonation = better knock suppression. Thats my opinion.
