mine did the same thing, hit peak boost then fell off jaggedly. found my exhaust housing, bov, couple of vacuum hoses, brake booster hose was leaking when i touched it. didnt leak when i tested it without touching it. good luck, mad props to u.
foreverpsycotic said:last i saw, meth was 114, regardless. you should be well over 600whp at 29psi.
hottscennessey said:looking at other dyno graphs I feel like now that I fixed the boost falling off problem.. I'm making my peak HP and torque at the same place as other cars making 600+ RWHP. I'm gonna hold off a little while on dynoing again, at least until it's cooler outside. 97* temps can't help #'s.
tissimo said:I dont think methanol is that high.. Its low 100s.. I think ethanol is 120-130.. I could be wrong though..
