aye mate said:Steve prefers "ninja hands"
yannis-supras said:Not throwing stars and daggers from inside your supra, are you? I thought you'd need them hands for steering :evil2:
yannis-supras said:Steve what kind of lag do you expect with that size of intercooler and the wide i/c piping? I was checking your i/c and it obviously has some serious air capacity. Needless to say that we have totally different setups, I was thinking about that regarding my i/c and piping and I have some serious suspicion of ending up with too much lag induced by the large i/c & piping.
Justin727 said:well did you weld up the cut on ur thumb? O btw I forgot to let you in on a secret. The tig like i said was a magical machine but it cant weld flesh back together. gosh.![]()
Ok the turbos outlet ID is 35 or 38mm x 2, I'm not sure as I don't have the turbos here and it's been a while since I last checked them. These two are connected to a two in one pipe that has two 50mm ID legs to a 74mm ID pipe to the intercooler, the core I think is 600x300x100mm (~23.5"x12"x4") then the cold side of the i/c has an 80mm ID outlet that graduates to a 85mm pipe that ends up to the Q45 tb (85mm ID).group a supra said:yannis i dont think the lag is gonna be more than i expected as full boost should be about 5500-6000 as i hope to have 10lb's bt around 3500
as for yours i dont think it would be a problem measure the outlets of the turbos diameter and give me the intercooler pipe size and i will tell you if you are there or not![]()
Justin727 said:lol i feel your pain buddy. I have too once shared this welding of the thumb together. Hope it gets better soon! I always enjoy looking at ur thread for updates. Hopefully the rain and the bum thumb wont slow ya down!
yannis-supras said:Ok the turbos outlet ID is 35 or 38mm x 2, I'm not sure as I don't have the turbos here and it's been a while since I last checked them. These two are connected to a two in one pipe that has two 50mm ID legs to a 74mm ID pipe to the intercooler, the core I think is 600x300x100mm (~23.5"x12"x4") then the cold side of the i/c has an 80mm ID outlet that graduates to a 85mm pipe that ends up to the Q45 tb (85mm ID).
yannis-supras said:Justin that's just dye, he didn't burn that thumb, he's just showing off those "ninja" hands again...:biglaugh:![]()
Wow man that's quite some math you did there, still haven't got a clue how you got your results :aigo: :biglaugh: . Doesn't the i/c core size has to do with lag as well as the actual i/c piping length? Come on Ian, quit lurking!group a supra said:based on that i dont see it being a problem as it progresivley gets larger towards the tb so let look at this logicaly as me and ian do on many an occassion lol
3.8cm diameter gives you a surface area of 11.34cm
11.34 x 2 = 22.68 cm combined surface at the start point.
the 5 cm inlets have a surface area of 19.63 cm each
19.63 x 2 = 39.26cm
the 7.4cm inlet has a surface area of 43cm so only a slight increase on the 2 5 cm inlets
and your tb at 8.4 cm is 55.41 cm surface area so it is a gradule increase which i think would be ok but check with ian if your not sureor just want a second oppinion
yannis-supras said:Wow man that's quite some math you did there, still haven't got a clue how you got your results :aigo: :biglaugh: . Doesn't the i/c core size has to do with lag as well as the actual i/c piping length? Come on Ian, quit lurking!
0>10 psi in 24 hoursyannis-supras said:Steve what kind of lag do you expect with that size of intercooler and the wide i/c piping? I was checking your i/c and it obviously has some serious air capacity. Needless to say that we have totally different setups, I was thinking about that regarding my i/c and piping and I have some serious suspicion of ending up with too much lag induced by the large i/c & piping.
P.S. Yes there are smaller intercoolers than yours that can still be considered large :biglaugh: :yelrotflm
