GrimJack's latest build project
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
More pics... got the rear main seal on, and the oilpan. If I'm lucky, and it's not raining TOO hard tomorrow, I might bolt up the clutch and tranny and drop the sucker back in the car tomorrow. :)
TobyCat
470
Vancouver BC
wow, you're making awesome time on this thing. A little bit every night and next thing you know you're talking about dropping it back in tomorrow :)
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
i thought you got fule reg and stuff what the stock stuff still doing there or is this for break in purpus
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
I left the stock fuel system on until I could figure out where the new stuff went. It's gone in the latest pictures. Speaking of pictures... Got a little help from a buddy today, and this was the result. :)
Jaguar_5
It's ALIVE!
Feb 7, 2006
1,468
Seattle
Fantastic progress!
I'm so envious of you right now, i want my engine to be done already!
Stupid missing pieces that take too long to arrive!
Can't wait to see a startup video! (hint hint nudge nudge :biglaugh:)
Is the crank pulley off for clearance?
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
did you manage to change the rear main seal while the motor was on the engine stand?
Also, is that a new wiring harness I see? Looks far too clean...
nice work
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
No, I had to lift the engine with the cherry picker, remove the stand, and then I could get at the rear main seal. I did put it back on the engine stand after that to do the oilpan and a few other bits. The wiring harness is the original one, however, I did recently rip off most of the loom and tape on it, then replace them both with new stuff. It's basically new. :)
NashMan
Aug 5, 2005
4,940
17
Victoria BC
ewwww felpro i have issue wiht there injectors gromets they freaking leaked on me on 2 car i have used them on and my buddie bob's leaked as well
i just buy toyota now
trydrew
Suprafied
Nov 4, 2005
1,038
Earth
Yeah I would swear that looks just like one of the ebay kits that I bought for my misc gaskets. I ended up buying many gaskets from Toyota. Some things that leak were the valve cover gaskets and the cps o-ring, just to name a few. I actually put my old v.c. gaskets on cause the were better.
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
Well, no pictures today. All the work accomplished was under the car, and taking photos under there is... well, not a trivial task. ;)
I did get some stuff done before the monsoon hit, basically hooked up everything underneath from the transmission back - ground wire, driveshaft, clutch slave, crossbrace, third engine mount, clutch fork, speedo cable, all done.
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
The monsoon ended, and the sun actually peeked through for a couple hours. So naturally I went back outside, scrunched down on the wet aggregate driveway, and got some more work done. :)
Installed the fancy new CPS cover from ARZ, too. That thing is just plain AWESOME. Check out the total wreck that my stock piece was when I took it off!
