Getrag 6spd
ma70mkiii
139
ohio
How hard is it to mate a getrag 6spd tranny to a 1jz and what all would you need to do it. I am going to be driving this car quite frequently and mostly on highway and was wanting a lower gear so this thing won't guuzle the gas like my 7m does. Plus I figure a 6th gear will help a little even if I have to shift 1 more time.
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
Once again, search. The problem with the Getrag is that it doesn't fit in the the tranny well without a lot of modification. Not worth it. Plus, the tranny's are about $3000.
Just keep your R154 and change out the rear end for one with a different ratio.
bigaaron
4,692
Pomona, CA
www.driftmotion.com
I have one for $2800, but there are other parts needed on top of that.
You would want to regear your diff with a lower ratio (~3.2)and make a custom driveshaft. You wouldn't have to make a complete driveshaft, just the front half, which I would do at cost to help with the project. You would also need a 6 speed clutch and flywheel. It has a slave and fork included.
Jostar
AEM powered 1JZGTE!!!
May 21, 2007
746
Chicago
Who can make a final gear ratio that low for MKIII?, I have only seen a 3.25 final gear ratio for the MKIII once, It came out of a TURBO A model, A guy from holland has the diff, Is there a company that can copy that final gear ratio & make it, I know it will be custom & asking TRD will be impossible to get a answer from then cause they probably think am crazy.
bigaaron
4,692
Pomona, CA
www.driftmotion.com
Toyota is not the only one who makes a ring and pinion set. Call an off-road drivetrain place in yor area and inquire about it.
bigaaron
4,692
Pomona, CA
www.driftmotion.com
viperkillertt said:
You will not receive much fuel savings with the 6 speed. The final drive ratio is very similar to the r154. So not a good idea.
It's not about fuel savings, it's about a manual transmission transmission that can handle 1500hp!!! :aigo:
OneJoeZee
Retired Post Whore
aboard the Argama
But that's not the intention the OP expressed.
He just has a misconception that 6spd = lower gear/better gas mileage. Which isn't true.
If the Getrag was a double overdrive, it would have made sense.
bigaaron
4,692
Pomona, CA
www.driftmotion.com
It's going to cost like $6000 even if he did the install himself, it would take a really really really really long time to make up $6000 in gas savings.
That's why I disreguarded the origional question and just stated the obvious.
If you just want to save gas buy a cheap daily driver that gets 30+ mpg.
OneJoeZee
Retired Post Whore
aboard the Argama
Kinda like buying an expensive hybrid then counting your pennies til it actually starts saving you money.:biglaugh:
Jostar
May 21, 2007
746
Chicago
To be honest with you i wouldn't know who to call, Do you have a company in mind?? can you help on getting info on the custom ring and pinion??
Spaniard
524
La pearla PR
Lots of modification? I dont think so. Maybe with shifter linkage, but a couple good bangs to the tranny tunnel and it fits.
SupraClaou
846
4
Athens,Greece
+ 2
Two bangs' to the tunnel will do !
A guy in Australia did the getrag installation on mk3 supra :icon_razz
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
I have seen it done, but IMO there is no legit reason to do so. Anything north of 500whp for me and its time to swap to auto.
Jostar
May 21, 2007
746
Chicago
I rather have a getrag, I have met a few big horse power supra owners & have told they rather have a 6 speed than a th400, TH400 for drag racing is the shit! The guy that i met told me that the tranny runs real hot & he had so many problems with the torque converter it wasn't funny.
