Furious But Lazy 7M owner who gave Up.
Dyzzyman
57
Arizona
Thought it was...
Instead of...
Albert;1918653 said:
Tranny is fucked.
Time for
Jordan,
How old are the master and slave cylinders?
Btw, the stuff on the bell housing, is that from the master blowing out fluid or elsewhere? Transmission seems quite dirty for how little you've driven it. I seem to recall it being cleaner is why I ask.
Turbo Habanero
4,229
Tucson,AZ
I'm not sure. It was a hell of a lot cleaner before.
Slave I've never changed
Master is new but obviously not installed correct also a cheap auto zone part.
Albert
May 13, 2009
1,710
Tempe, AZ
Okay Jordan, I have a Slight recipe that may work for a r154 to last a little longer than a week for you ;)
First get al lthe MC parts
1 retainer plate
1 Thust washer
1 1-2 billet fork
1 3-4 billet fork
After that get the rebuild kit. I went with Cobra Transmision and so did Dutin. $160 for the same stuff you get from DM.
http://cobratransmission.com/index.php?main_page=product_info&cPath=2_2066&products_id=50276003
It has the upgraded/revised 3rd and 4th syncro, and the Upgraded full compliment roller bearings for the counter shaft.
Stock synchro:
Revised Synchro:
Upgraded roller bearings:
Then you really need to look at your Hub, Sliders, and engement teeth on the gears to see how rounded they are.
Mine were pretty bad, even tho it shifted fine, you want these things as pointy as possible just like the syncros. Luckily I had a friend send me sapre R154 parts, and his sliders, hub, and engament teeth were alot pointier than mine. So I used his. this sound really really help the sliders engange a given gear easier. Easier is better. Missing gears while shifting does a number on the tranny.
Here is why my sliders looked like:
This was one of the best ones, I can grab a photo of the worst ones, which was more rounded
Here are new ones you can buy:
1-2 Hub:
http://cobratransmission.com/index.php?main_page=product_info&cPath=2_1837&products_id=50047037
1-2 Slider:http://cobratransmission.com/index.php?main_page=product_info&cPath=2_1837&products_id=50047039
3-4 Hub:
http://cobratransmission.com/index.php?main_page=product_info&cPath=2_1837&products_id=50047038
3-4 Slider:
http://cobratransmission.com/index.php?main_page=product_info&cPath=2_1837&products_id=50047040
5th Slider:
http://cobratransmission.com/index.php?main_page=product_info&cPath=2_1837&products_id=50047041
The Gear Oil I went with was the Redline Lightweight Shockproof.
The reason behind it is: Yes MT90 is amazing shit for the R154 as a daily, I just find the shockproof might help us High HP guys.
Plus it's blue which is cool
