Furious But Lazy 7M owner who gave Up.
Albert
May 13, 2009
1,710
Tempe, AZ
It can be done without relocating, I'm running shroud and 3" piping.
If you're running 2.5" piping, you can run it down like me. Even with an upgraded radiator. Like mickeys 2jz
Turbo Habanero
4,229
Tucson,AZ
Okay so far i bought
1JZ Engine Gasket Set
1JZ Pre 89 Motor mount Brakets
Front mount intercooler
1JZ Serpentine Belt-No AC 1JZ
1JZ Standard Ring Set 1JZ Standard Size Ring Set
1JZ/2JZ 90deg PCV Valve
1JZ/2JZ Bell Housing Bolt Set
1JZ/2JZ Oil Pan Bolt Set
1JZ/2JZ Inspection Cover 1JZ/2JZ Oil Pan Inspection Hole Cover
1JZ/2JZ Oil Sender Adapter Hose
1JZ/2JZ Oil Pump
1JZ/2JZ Spark Cover Bolt Set-8 Bolts
1JZ/2JZ T-Belt Hydro Tens-Factory Toyota
1JZ/2JZ R154 Bell Housing
1JZ/2JZ Cam Sensor (only needed one sense it was missing)
1JZ/2JZ/7M Valve Cover Bolt-With Seal Washer (X 16)
2JZ-GTE Throttle Cable
AFPR KIT 1JZ-12mm (stock rail) Aeromotive AFPR Kit for 1JZ-GTE
Lower Oil Pan for Rear Sump 1JZ/2JZ
Radiator Hoses JZ MK3
R154/W58 Bell to Trans Bolt Set
Supra MK3 Battery Tie Down Bracket
Clevite Bearing Set for 1JZ/2JZ
ARP 1JZ Flywheel Bolts
ARP Head Stud Kit 1JZ/2JZ
1JZ Timing Belt Idler Pulley
1JZ timing belt 1JZ timing belt
1JZ ECU
T3 T67 turbo (Albert)
1JZ Igniter (Clint)
1JZ Engine Harness (George)
2JZ Map Sensor
Still need
Flywheel
Downpipe
Softline oil kit for turbo
Intercooler piping
BOV
Solid pre 89 Motor mounts
Possibly new wastegate
Turbo Habanero
4,229
Tucson,AZ
Ok so I figured since I already went way over my original budget I said fuck it and I'm just going to get this done.
So my question for you guys is the DM lightweight flywheel worth the $350 plus ship? Or should I just buy a stock one ?
IBoughtASupra
4,455
Queens, NY
So I was with this girl as a friend for four months and then dated her for an additional five months. Then she told me she was nine months pregnant. So I said, I known her for four months, hit it for five, four plus five is nine right?
Sounds about right to me.
Wait a minute, I thought this was Dr.Phil's build thread with all the taking happening here and no photos.
