dual walbro is going to be cheaper, but like others are saying the fuel will get sucked so fast that it will go dry at 1/2 to 1/4 tank, the other thing is like what the last guy just said, if a pump fails it will go lean and have potential at blowing your motor, with the external it will be a tad louder and will cost a little more, i just paid 70$ for a sump and 310$ for a a1000. but with both your going to have to buy some stuff for electrical, wires/relays/connectors. they say with a dual walbro your supose to use the electro magnetic wrap from MVP but other say you dont, i would though just in case. with the external your going to need a pre filter and a filter after the pump as for the dual i would say just one filter would do, as for the pump getting hot for the external idk bout that
i remember duane saying he did some major road trips on his a1000 no problems. both of the pumps are going to require some extra work though for mounting them "still trying to find a area for my a1000" the dual pump setup there is a hanger availible but for the price of the hanger and 2 pumps you might as well have just bought the external. if you have a welder or a friend with a welder i would be bugging him as much as possible to help you out with this project as it will be required for making mounts/hangers/bunges and fittings. then you will also have to decide on the size of your hose's for a dual i was told to do -8 feed and a -6 return. the external im planning on doing -10 from tank to engine then split to x2 -8 for a dual feed and either a -8 or -6 return. but im also going a little overkill so depending on what kinda injectors your going with and the hp your planning on going for the size for an external could be changed, my case im going with 850cc RC injectors and 700+ hp. keep your eye out on ebay for some fuel pumps and see what you can find, just do what i did and think of the future and not your pocketbook. if you would like to take the risk of blowing your motor go for it, but dont say i didnt tell you so
![Stick Out Tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
. or buy the dual walbros now and get an external later. btw i've got a 255lp walbro for sale now its brand new never been used 80$, pm me if your interested. good luck with the build
