I just got done with a test drive after adjusting my clutch. Jay, you can finally relax, I have found the need for a new boost gauge. The car is now stronger than the grey car ever was, but still lacks some of it's power. I now sincerely believe that it is due to tune. I have the NEO adding fuel at all times, because I still have no wideband yet. The boost controller is not maxed out either, but now I gotta start reading instructions on it.
I'm still not 100% confident in my clutch. I did smell a little bit of clutch on that run. I don't know if I have glazed it over, or created hot spots on the flywheel. Or maybe there was just a little residue to burn off from earlier runs since getting the timing right. I still haven't run it even to 5500rpm, and haven't even taken that to 4th gear.
