Flywheel, Pressure Plate & Clutch wear?
GeneStarWindGSW
Been To The Other Side...
Mar 25, 2007
992
No Man's Land
www.bidmingle.com
I'm just wondering since i just bought my R154 transmission a while ago, im thinking is it ok to go with the stock PP and a used 6 Puck clutch and new 1JZ Flywheel?? I have pictures of everything and i want some feedback to see if its all good to use. Btw i have two PP's and im not sure which is better. (The PP from ebay looks like the stock Toyota one.)
The guy i bought the clutch kit from included the PP(Darker one) & the 6 puck clutch.
He said it was this exact one.
http://cgi.ebay.com/ebaymotors/86-T...tegoryZ33730QQihZ014QQitemZ330131056745QQrdZ1
EVERYTHING! ::w00t::
New R154 PP (From Ebay Auction ) [Looks like the Toyota One ..even says toyota at the botom]
R154 PP That came with 6 Puck (Ebay) [Back]
Stock R154 PP (Front) [Has throw out bearing it in already & stuff :icon_conf]
Stock R154 PP (Back)
6 Puck Clutch Pic #1
6 Puck Clutch Pic #2
6 Puck Clutch (Back)
Stock R154 Clutch
R154 Turbo Flywheel
1JZ-GTE Flywheel (Front)
1JZ-GTE Flywheel (Back)
Just looking to see what you guys would say about this & your feedback on it =)
I wouldn't put that used clutch in my car. You'll be dropping the transmission again soon to put a new one in there. I'd rather do it right the first time. Good luck either way., Jay
Tim
regular member
Oct 16, 2006
272
CA
yah man, don't ruin that pretty 1jz flywheel with a crappy used clutch. Just save up and do it right the fist time, and you will be a lot happier in the long run.
Ckanderson
2,644
The beach
hehe... the exact advice I gave him...
Pm me.. maybe i can help you out with a clutch if you send me a mystery box....
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
I hope you're putting this on a 1JZ because that 7M flywheel looks cracked to shit.
The ebay flywheel is an OEM one, but it may have been heat treated to make it stiffer (doubtful by the looks of it though)
I would also suggest getting a new clutch, don't put a used one in. I would also get the pressure plate resurfaced.
ebay PP is used... (finger wear)
disk is used as well...
I'd get a new clutch personally...as dropping the tranny isn't fun. I'd also recommend replacing ALL of the throwout bearing assembly (hub, bearing, clips, washers, ect)
GeneStarWindGSW
Mar 25, 2007
992
No Man's Land
www.bidmingle.com
SPEC Clutch Stage 5 7MGTE
High-clamp load pressure plate, iron disc, bearings and a tools/710 ft/lb Torque Capacity
$503.00/Clutch kit can be lightened for an additional $79
Or
CKanderson's ;)
6 puck sprung hub Xtreme pressure plate rated at 632 Ft pounds
$477.93
which sounds better? reasons why? differences?
Ckanderson
2,644
The beach
^ haha, go ahead and order the stage 5, then regret it ;) Dont buy the stage 5.
you can also do xtreme pressure plate with the full disk if you prefer.
I have ran a 6 puck sprung hub in every supra I have ever owned. they chatter a LITTLE when cold and slipping it (reversing out of the driveway was the time it chattered)
After a small drive it ran just like a normal clutch.
Ckanderson
2,644
The beach
an iron disk?
Biggest on/off switch. I would never recomend an iron disk.
The 6 puck has friction surfaces (the pucks)
an Iron disk is just that, Iron.
