ffim available in the near future?
Jack
358
Stillwater, MN
Alexashka;1246032 said:
Would 100% buy 1 if you manage to send to Europe.
My European sales will be handled through Silverline Racing. I know 10 will be heading over there when they are in production
If your not sure if you are on our mailing list just goto my website and put your name in the newsletter spot on the lower left hand side of every page. I go through on a regular basis and delete doubles.
Thanks for the response on the FFIM so far!
Cruise control works off the mess of a system behind the 3000 pipe.
I've been trying to figure out if the JDM cruise control will work on a LHD car, and if it's compatible with our existing system. The JDM setup moves the pedal, so it works fine with a FFIM (like IJ has).
Jack
358
Stillwater, MN
Same ETA, we brought in another local company for some of the design work since Greg is out of it for a bit.
I hope to have the prototype printed and mounted in my car within two weeks.
We made it so the stock egr system will work or use the LIPP egr block off plates. Factory cold start will work.
You may notice the two spots for the IAC, once we get the prototype bolted in the car we can see were the IAC will fit best.
Now that it has been brought up, we will work on getting the cruise control retained, I will not drive my car with no cruise (much to lazy)
Muzy
182
Alberta
I still am excited to see this being developed. But as I see the R&D start to pile up.
Somebody needs a port for this and a port for that. Man buy a drill and npt tap and have
at it. Modify. Now we are talking cruse. I'm just afraid it will push the cost outta reach.
But maby not. muzy
Jack
358
Stillwater, MN
Updated pics again today
the silverish color is machined surfaces. We also added a bigger LIPP logo on the back that will serve as a surface for the vacuum ports.
Also notice on the runners we added flats for direct port injection for nitrous on the top and bottom of each runner. Top if you want it seen or bottom for the sleepers
What do you think?
Mk3runner
2,033
Nor Cal
nice seeing progress, keep it up. are you gonna post up pics of final setup and maybe some pics of the install and final look. I like visual.
