Feeler on 7m 1ZZ coil Bracket
Albert
May 13, 2009
1,710
Tempe, AZ
jg5899;1962963 said:
Same here. Looking forward to see if you can make it a straight bolt on affair without the need to helicoil.
Yeah that's def the plan, but I won't know till I get the larger tubing and larger hardware. The tubing that's in there now barley fits. But I'm sure I can machine them with a taper toward the end. Still you will still need to get a hold of 4 of the rear nuts on the 7m, the one that has the threads in it.
I can always obsolete the last home for guys still on stock throttle linkage but I'd have to see it to work around it.
Albert
May 13, 2009
1,710
Tempe, AZ
Still working on the new design and finishing turbos and that fuel rail I was making.
