Feeler on 7m 1ZZ coil Bracket
gurley0916
Gurley=Last Name not girl
Mar 10, 2008
1,138
Columbus,OH
Mr Bojangles;1883992 said:
If you can adjust the mount holes for a 2JZ I'd take one.
Or if you ment for a 2jz motor there is a 3 piece option
The bracket just needs to be fabricated. The CAD file is confirmed. Just waiting on the mad scientist to have time.
Albert
May 13, 2009
1,710
Tempe, AZ
Okay ramping up to make these.
Sold 3 today.
How many more people want in?
Also per request I'm looking at the same bracket but with is coils, and 2jz coils.
lithium14
995
Austin
I want to do this so much. Now that schools over, I can focus and do some research on how and why I should do this =D
Sep 19, 2011
510
Des Moines, IA
Sold 3 today.
I will be buying one very soon. Have you made any progress on the 2j or is coil bracket? I might do some research here, and see what set of coils I will be wanting to run. I did just buy an aem v1, so I will be ready to do this sometime soon.
Enraged
A HG job took HOW long??
24
Victoria, BC, Canada
gurley0916;1899778 said:
is the aem batch fire? if no then trigger goes to each coil as they are smart coils.
the v1 only has the 3 ignition outputs, so I'm wondering if you just split each one, and run the coils in batch fire?
Sep 19, 2011
510
Des Moines, IA
Okay, so if I am correct on this I am thinking the firing order on our cars are 153624. So this is what I am thinking, I need to wire 1&6 together, 5&2, and 3&4. Please tell me if this is what you guys are referring to. (i may have the firing order wrong, but this is just off of memory.)
Orion ZyGarian
Jeff Lange wannabe
Apr 2, 2005
1,490
Sarasota, FLorida
www.suprastore.com
Yep, that's it. It'd work in wasted spark form similar to stock
Albert
May 13, 2009
1,710
Tempe, AZ
The 1zz bracket I have now is $125.
Buddy is coming over with is coils so I can make a bracket. Along with 1jz/2jz coils. Just busy so may be a while
First batch of coil brackets I made got messed up. So I'm out that money. With the holidays coming up, ill try to get them done but I can promise anything.
