figgie said:IHI
the problem is not ths stud
the problem is the thread count that is course on the head side and fine on the nut side![]()
bigaaron said:It is easier to tap good course threads then fine in the head. The corse threads are taller so it bites better in the aluminum.
figgie said:ohh i agree 110% with ya
I am doing something special and need the beefier studs
and this actually is a perfedct segway into my other question
if the head has been drilled and tapped for 10mm x 1.25 can we no longer drill for 7/16?
bigaaron said:If you had a 10mm helicoil strip out you can use the new helicoil tap in that hole still. So yes, you can pull out the old 10mm helicoil, drill it to 29/64 with the supplied bit, and tap it for the 7/16 helicoil.
Jaguar_5 said:Thanks aaron! Got my kit in
Although (excuse my termonology) the thread tap didn't quite fit into the.. tool. I had to bend the 4 tabs out a bit, then 'ease' it in, lol, it'll work though but a helluva squeeze
TaSe said:sweet is there a in car kit for 7/16?
