emiliorescigno;1155087 said:Rob - if you don't mind me using that elbow that would be perfect. Sean's DP is a full 3", mine has that crappy 2.5" inlet. Having that wideband hooked up will really help out with diagnosing my richness.
I can just go down to SupraSport next time I'm home in Stillwater (more MN Supra guys - woot!) and get a 3" Elbow then, and call it a day.
Figgie - think you'll have your car all ready to rock by next spring? We need an MN meet, I think Minnesota Supra owners are finally coming out of the woodwork :icon_bigg
scubajtw;1248665 said:Minnesota party!!! Hope all is going well now under that snow pile.
scubajtw;1248665 said:Minnesota party!!! Emilio where are you from in Stillwater? I live just a few min away from suprasport... like maybe 2 minutes in West lakeland. Tough luck i see you are having with your car... I know the feeling! Hope all is going well now under that snow pile.
92nsx;1248806 said:His car is out from under the snow pile (the warmer temps out helped out)and his new turbo is installed as of friday.
Hope this one dosent leak and or burn oil. So Emilio what is your next step?
funky_monkey58;1284016 said:Tonight after we get back from St.Joe lets get this bad boy running I have $20 on it not burning oil after those seals. Those rubber bits make sense to me why it would burn oil like a pyro maniac with a few cases of oil under vacuum conditions. With are passing under the valves and creating a suction effect I can definitely see it sucking up oil from the bottom of the seals and into the combustion chambers.
So lets get this bad mofo running and then start attacking the rust on it. I think we can still save this one Emilio.
92nsx;1288548 said:well 13-14 isnt to bad for idle, IIRC we want around 15 on idle. but to spike rich once to open up the TB ummm..... But we can take 51, it is a easy fix. I just took care of mine. It is just time consuming, with the feeler gauges and once tighting the screws on the TPS it moves a little so I just did little by little with my multimeter pluged into my TCCS so I could watch it. If anything we can take care of 51 today after we get the rear end in Dan's car. I have LOTS of time on my hands now to turn wrenches on supras![]()
