Just ordered a det3 from Zach at ECUmaster. I am wanting to do a walk through for everybody and some videos as well to get people on board since its hard to find anything on it .its on its way now and were running it on a 7mgte also .
I have your wiring diagram and wanted to ask you a couple questions on it . why you had to do the multiplex delete if that was to be able to do timing adjust or if it has to be done to get it to work at all .I want timing adjust as well.
Also is the KS on your diagram is knock sensors there was a KS also by the afm meter on the diagram. could you tell me what the second KS is? and did you hook up only one knock sensor as well.
Did you hook up the unit to a afr 02 sensor to get a reading for it and what pin did you hook it to .
It would really help to have your saved map if you could email me it to have a good starting point id really appreciate it. Also just to know what to do where in the software without being blind. my Email is
strokeitimports@Kc.rr.com
Any pics you can take of wiring and under hood of map and air temp sensor would be so helpful too of your wiring and install if you get time .
I really hope you could help me out with this and i will help everyone else out once i get it going . Appreciate your time thanks Dave ,
