I was running speed density (no afm) but I did not have the table setup for the gm iat. I added a resistor I believe it was the 2.2k, between the factory temp sensor on the afm.
Then you just wire up to whatever extra input on the det3, other to ground on det3. The wires are not polar. After that's all hooked up you should be able to load the gm scale, then assign the correction for the input you're using in the table setup menu iirc.
It's been awhile since I looked at the software I believe I have a picture of the setup on my laptop
Sent from my LG-LS980 using Tapatalk
