How is it now that you have it on? Sound? Performance difference? If you went back in time, would you buy one again?
dugums said:They will coat it in base 1300 sterling for $70, 1700 extreme sterling for $120, and JET HOT 2000 for $150.
The extreme is probably suitable, but I do things a little overkill. As the temp rating goes up, the finish gets more gritty/less shiny.
The 1700 is pretty much the same as most chrome ceramic "2000" I have seen. Keep in mind that temperature rating is only a guide as to "peak" temperature, not constant.
theprodigy79 said:How is it now that you have it on? Sound? Performance difference? If you went back in time, would you buy one again?
theprodigy79 said:Damn, we need to get someone to buy both a BIC and the ZW and do a direct comparison on the same car!!! Hell, I'd chip in for that!
van1684 said:i have a bic ddp. where are you going to do the dyno? i'm in chicago.
dugums said:Is yours a recirculated DDP? Because that would probably be the one worth comparing.
dugums said:Well, I got the DP today. I won't be able to comment on fit yet, as I won't be installing it for about a week.
Any update on the fittment?
Supra469 said:Any update on the fittment?
RedEj8 said:I think the only thing id be worried about with the ebay DP is the flex section. Ive seen too many instances with crappy flex pipes collapsing on the inside. These were setups on turbo hondas. The 3" flex would look normal on the outside but once you take a look inside the pipe, it would be a tiny little 1 1/2" hole.
Supra469 said:Geez. There's just no winning with this, huh.
I wonder if the 935 DP would be questionable as well????
I dont know if you were talking about me but i did not say anything about this pipe in particular... I was just stating something that has happened to me and one of my friends with a shitty flex pipe(from ebay)..I havnt seen inside pics of the said flex section so i dont know what the quality is.dugums said:I don't know what the guy above you is talking about.
Everything appears to be really nice -- I haven't mounted it yet, but everything about the pipe is top notch.
The 935 pipe is likely identical to the ebay pipe (same people make all of these).
The poster above you shouldn't be saying anything unless he has experience with this specific pipe.
