ebay recirculated DDP - fitment and specs?
Supra469
495
Maryland
I just had mine installed and well, it sounds nice, feels nice but too soon to really tell ~that~ much difference, i'm waiting for my RT cat to come in & Tanabe SMH cat-back so that I can really flow freely. :D
Got to figure out what to do about the heat shield now???
I bought one from 935 motorsports and it looks great. I'm going to install it this weekend along with some 3" pipe and a magnaflow muffler. P.S., it's going on my wife's 7m and not on my car.
Supra469;944693 said:
Are there are side effects to have all that heated pipe wrapped up, like does the wrap allow moisture to get in and eventually corrode etc?
Not when it's ceramic coated.
Also, you can modify the part that bolts to the back of the elbow on the stock heatshield and it will fit on and look stock, and work as it should.
Supra469
495
Maryland
Cool. Now I have to source a stock heat shield! :biglaugh:
BrandonW
1,300
N.J.
what do you have to do i also have one but im waiting on alot of other stuff befor i put it one with the rest of my exhaust when it comes
Basicly the flat part where the rear nuts holds the heatsheild to the elbow needs to be cut off.
It's pretty easy to figure out what you need to cut is you test fit it...
BrandonW
1,300
N.J.
ok cool thanks
SlimLim
170
Australia
Has anyone got pics to show how close this exhaust sits to the chassis. I'm chasing a downpipe that sits quite high up.
Mine actually was riding right on the crossmember for the tranny...
TONS of vibration, so I put a strategic dent in it so it doesn't touch to solve it...
Can't get any more tucked up than that, maybe if you went with oval piping...
Oct 11, 2005
3,819
20
Thousand Oaks, CA
At the cat end, the position is defined by the hanger, so it is basically the stock centerline, except the pipe is bigger so that pushes it a little closer to the body.
