7MsuprO said:Pics of new setup? Sounds nice...esp not having to run those butt ugly heat shields.
I need to get her cleaned up before I take some pics. Hopefully tomorrow, but the forecast says rain.
Poodles said:function > form
the heat sheilds stop the heat from baking everything in the area (like the coolant lines, wiring, ect...)
7MsuprO said:I've seen a few ceramic coatings advertised as "no heat shields needed after application." I think i've also seen JDub say that regarding his but don't quote me on it. Not that i have any experience in the matter but id love to not have to use them if theres an alternative.
jdub said:Ceramic coating is good, but if you have provision for heat shields...I'd use them. Anything to keep the heat down in the engine bay is a plus. On my next downpipe, I'm going to ceramic coat it and then wrap it.
If you don't have attachments for heat shields, I would most definitely ceramic coat the exhaust parts...don't go cheap...use a 2000 deg rated coating at minimum.
theprodigy79 said:Absolutely love mine... Boosting over 8PSI (stock gauge) with just the DDP, Random Tech 3" cat on stock cat-back and A'PEXi Power Intake with no boost controller in this cooler weather!
starscream5000;884333 said:What type of coating is it?
starscream5000;884460 said:Wrap it to the cat/test pipe, you'll notice a difference in temps.![]()
