Ebay oil relocation kit.
QWIKSTRIKE
475rwhp459torq an climbin
Apr 3, 2005
1,172
Some where out there
Figgie has a good relocation adapter. I have an Earls relocation billet adapter and it doesnt rotate to allow to place the fittings anyhwere that you like them. That is a good quality piece Figgie...good score. I may have to get one of those. I am using a b&M cooler 27066 I believe and a b&m t stat. That t sta looks good but mine suffices. I am running dual fileter mounts to help with cooling and filering by adding more oil. I am using mobile1 m1 301 oil filters which hold a quart of oil each. In total I have 9 quarts of oil. Whats good there IJ. Pop over to SF from time to time dude. lol;)
theDon
The Don
Med-City, USA (Rochester, MN)
QWIKSTRIKE
Apr 3, 2005
1,172
siman said:
Its the stock 7m filter from Toyota ( I only trust OEM filters).
As I said, the JZ series and M series ( which includes the 7m) all are the EXACT SAME OIL FILTER.
I use the mobile1 M301 filter. The filter is huge holds about a quart of oil, and it out shines all the rest. My relocation kit, and shimmed oil pump sees 100psi on start ups cold if I go over 2k rpms. The winter cold makes oil thick, and the pressure is higher than summer. During the winter higher oil pressure on start ups made all other filters keep bursting. Then I read that the mobile 1 filter had technology that lets it flow oil in cold temps and not fail. After reading that I decided to try it. The filter works flawlessly and holds more oil. The benifit of more oil is that more oil volume gives more cooling.:biglaugh:
Ant: We no longer have the pleasure of Siman's posts so he won't see this!
I use the Moroso race filters for some cold start peace of mind as they're heavy case construction and laugh at 100+ psi :)
