Driftmotion 1JZ 60-1 Single Turbo kit dyno results?
mensrea
211
Schofield Barracks, HI
Mine went out after about a year, but i had a bad oil and exhaust leaks. Still have manifold and waste gate that came with the kit, running 6265 with no issues for yead and a half now. Also, that '61 took me across the US 3 times, and i was running 21 PSI daily.
BoostMonger
PUSH IT TO THE LIMIT
Sep 5, 2011
880
Shadows of Utah
I bought my car with this kit and I've had the car for over a year, after I fixed all of the POs shit I was surprised how fast it spooled, and eventually had to put beefy springs in the WG cuz it was pushing itself open at about 17.5 psi. Never had a single issue.
For those that say their WG leaks, was it an exhaust leak? Did you check the gasket? Or was it a vacuum leak? Replacing the diaphragm is cheap and easy.
The turbo spools fast and pulls hard thru out the rpm range, don't have any numbers tho, havent heard of a dyno day in forever. So I'll probably be on a dyno for the first when I'm getting the stinger tuned.
Sent From My HTC One S using Tapatalk 2
