When does the Driftmotion 60-1/ .70AR turbo start to loose boost? I bought it to match my 264 cams, so I hope it'll stay at maximum boost until at least 7500rpm
upgradedsupra;1441825 said:PSI has a badass shop. I was there for my tuning with Reed. Didn't get a video, was having issues.
You guys not running meth with your set-ups? Stand alone, meth and more power on pump.
Duane
honestabe;1440964 said:93 octane with roughly 18.5 lbs. It would spike to 19.5 lbs but drop down to 18 lbs. I just spoke with Spaniard on the phone and this is what he told me.
honestabe;1441811 said:It all depends on what your supporting mods are. Every setup will be different. Why 7500 RPM's?
honestabe;1442007 said:Tissimo, it's not all the cams. This turbo is very badass. IDK what timing figures Jonathan had on his friends Supra, but with mine I can tell you the timing wasn't messed with since I still have the stock timing gears.
264 cams seem to peak ~ 7000-7200 peak power.Sam;1442085 said:7500rpm seemed like a good guess for me. 264 cams change the powerband so you reach maximum horsepower around there, correct? I just want the turbo to stay at maximum efficiency until then.
honestabe;1442119 said:I made 400 RWHP and 347 RWTQ on my 1JZ. Mind you this was with an SAFC NEO and 440's and the stock JZA70 ECU. I'm going ViPEC V88 standalone with Bosch 750cc high impedance injectors and top feed fuel rail now.
honestabe;1442111 said:Did you upgrade the springs and retainers when you put in your cams? Or are they stock with just the cams upgraded (like mine are)?
honestabe;1442257 said:OK, then maybe you can go to higher RPM's.
slideways2004;1441663 said:which powerfc are you using? an actual jzx90 or a converted one from a 2jz?
the reason i'm asking is b/c i'm going to be using one from a 2jz.
also, i would also like to know what injectors
partyboy25;1443142 said:Ok, and 1 more question. How fast does it spool up? How does it compare to the stock twins in spool time? Reason I ask is because it would be going on a drift car and would like it to be responsive. Thanks for all the info![]()
