drift
Mr.PFloyd
I am the Super Devil
Jun 22, 2005
3,964
Mississauga, Ontario
JENNY! said:
do all of you think i dont know what drifting is because im a girl? f u guys in the a.
definately not all of us. i got a lot of hot girlfriens that are into that stuff. im not but i know a lot of chicks are gettign into cars now. thus i do not beleve peopel like me think you dotn know about drifting.
OneJArpus
2,798
For a good Drift setup its all about the suspension. Our cars have a near 50/50 balance which is perfect as is. We don't weight much more then a MKIV and they can drive with out a problem.
All new suspension bushings, coil overs, traction arms, and any other old worn suspension part. Check the rear sub frame for cracks and replace if broken.
DLM
23
socal
www.geocities.com
This has to be the silliest shit I have evre read. Drifting is or isn't that, who gives a damn, that's all opinion anyway. Most of the comments are so cracked out that we can't even get started on opinions. The facts are that sliding is no where near as fast as a race line. Simple physics tells us that static friction is much higher then sliding friction. If you can't figure that out then show me one pavement based competion where the fastest guys are sliding. Fact 2 is that you want a front wieght bias. Again physics being that the end with more wieght will have a higher coefficient of static friction(more grip), therefore anchoring the front and allowing the back to swing easier as well as having less inertia making it easier to control its swinging. Again if you haven't figured out that physics has nothing to do with a mind reading hotline yet then why do you think corollas, s-whatevers, vipers, GTOs, i.e. front engined cars make great drifters. Also explains why those goofey truck conversions do so well (they have no wieght over the rear). Anyway the easiest way to make a drifter out any car is to cut as much wieght as possible while maintaining front wieght bias, and reduce body roll as much as possible (lower cg and stiffen everything: shocks, springs, sway bars, and tires).
Stanzaspeed
2.5 Twin Turbo R
Calgary, AB
well i was sitting around the university of calgary with a friend and some wench folk when one of the girls grabbed a blueberry pie from the fridge in her dorm room.
this temporarily distracted me from their boobs so i ate afforementioned pie off the floor and resumed staring at boobs.
and they all lived happily ever after
the end
