Day 1 was removal of the intake tract, but I forgot to snap pics.
Thus far on Day 2 -
Upper intake manifold is off, fuel lines are disconnected. Wiring harness completely disconnected.
For those with experience yanking the 7M + tranny, what else needs disconnecting before removal?
So far I'm thinking -
Radiator/Fan shroud/Fan
Driveshaft
Auto tranny crossmember
Motor mounts
Tranny shift linkage
I'm leaving the turbo hooked up, the a/c compressor on w/lines disconnected (one of the things I'm fixing while the motor is out - MY A/C - it is empty, and I want to vacuum/replace the accumulator while in there).
What else am I forgetting to disconnect here?
*EDIT* The power steering system, for one....
Thus far on Day 2 -
Driveshaft
Motor mounts
