Adjuster
Someone posted about the rack bushings being very close to ones already made for Toyota trucks? I'd like to know more about that, and see if these guys have a set, and/or can confirm what works, of if there is a close set that can be modified/ground/machined or otherwise used on our cars.
Or I can spend the money, and buy the expensive ones out there... LOL
The TEMS Tokico struts work great, so do the B&G lowering springs I'm using, but I'd like more ride height.
There are a few ways to get this, and maintain the TEMS setup.
1) Get new springs, or have these set at a higher ride height.
2) Add in spacers between the spring, and either the lower or upper spring seats/perch.
** Many stores sell a split rubber ring, about 1" thick, with a grove that can be inserted between coils, and raise the rate, keeping the car higher. (Jack up the car, then slide the rubber ring in there, and let the car down.. Instant height raise.)
3) Revise the lower mounts on the A-arms, and rear control arms. (I'm actually leaning towards this.. Adding a stronger mount for both the rear strut, and rear sway bar in the process, and adding 1" ride height all the way around. Also if the rear ones are moved in slightly, it would improve clearance for running wider tires..
Thanks for the update on the control arm bushings. Any word on the "list" price, and then what places like Summit will sell them for at a discount?
