do you really need a power steering cooler?
stevenr816
932
Phoenix,AZ
im putting my motor in soon and was thinking about the ps lines. i dont have a jza70 power steering cooler. so i have to either run it without the cooler, or run a long hose to the resevor.
so, my question is, do you really need a ps cooler?
stevenr816
932
Phoenix,AZ
OneJoeZee;926212 said:
Just go to your local autozone and pick up an auto tranny cooler. That's what I did. Install in 20-30 minutes. Problem solved.
just a universal one?
rakkasan;926218 said:
Yes, you do. 1J power steering pumps aren't cheap, and will burn out quickly without a cooler. Ask me how I know.....
how do you know lol? did you do it too?
OneJSupra
I'm a sleeper ...
Feb 9, 2007
900
Supraland
YES... I used a stock 7M oil cooler and also installed a magnefine filter. It works great.
If you can afford a JZ engine you can afford to buy a ps cooler... :biglaugh:
Slow_Sc3
I beat bikes dude
Apr 2, 2005
401
Maryland
hmm weird iv never had any problems with my power steering and i never used a cooler on my 7m and i dont have one on my 1.5jz.
OneJoeZee
Retired Post Whore
aboard the Argama
Just because it hasn't happened to you personally doesn't mean it's not a problem that should be addressed.
OneJArpus
2,798
run 1, i haven't ran my motor yet but a reman pump cost me 170. I replaced it cause i've heard of alot of ppl burning theirs up quickly. I just replaced it for safe keeping and i am going to either use the 7M oil cooler for the hydro fan & ps cooler. Or i may dish out some cash for a rail cooler from sumimt racing.
H 1.5 x W 12 x THICKNESS 1.5
http://store.summitracing.com/partd...1&part=DER%2D13222&N=700+115&autoview=sku
23$
tissimo
Stock is boring :(
Melbourne, FL
I just have a line run across the front bumper support..
Might put an actual cooler on it though, cause thikning about doing some road racing..
tissimo
Stock is boring :(
Melbourne, FL
89+s sorta had one.. the line that ran to the front of the car had some fins on it.. pre 89s just had a line running to the front
stevenr816
932
Phoenix,AZ
http://store.summitracing.com/partdetail.asp?autofilter=1&part=DER-13222&N=700+115&autoview=sku
23$
thats really cheap! maybe run two of them just to be safe since they are kinda thin, but compared to stock its beefy.
doom26464;929230 said:
does the ma70(7m) come with one stock?? Becauses I don't remeber my car having a power steering cooler anywhere:aigo:
yes it does its between the radiator and the front bumper, follow the lines on the passenger side and it will go to it
yankiwi
221
DFW
Anyone considered using the tranny cooler in the stock radiator for a PS cooler?? I am trying to fit all the radiators/coolers and I am running out of room. I would like to hear any opinions on trying this.
stevenr816
932
Phoenix,AZ
very good question! i dont know if it would work only because the stock one is air cooled and the radiator is always ~170 degrees compared to air temp so idk?
