gaboonviper85;1432971 said:Wastegate makes it's own unique sound which is why you hear it
you don't think i would hear the leak unless it was minimal since i can hear the wg open?
if you have an exhaust leak, you should be able to spot it at idle. try blocking off the muffler for a little bit, it makes spotting it a little easierBrandonW;1432987 said:you don't think i would hear the leak unless it was minimal since i can hear the wg open?
theKnifeArtist;1432988 said:relax, its not useless.
install it and see how you like it.
then make plans on the whole tab situation
gaboonviper85;1432994 said:You can hear the wastgate open in a regular downpipe that's not divided....esentially you have a normal downpipe with a funny looking tube...so no I don't think you'd hear it as it never actually leaves the exhaust system...think about it a bit...with a divorced dp you'll have non muffled exhaust leak that will indeed be annoying but if you reroute back into the exhaust you esentially eliminate said leak...it would be damn near impossible too hear...
But yes in a regular aftermarket non divorced dp you can still hear the wastegate start too open.
supra_guy;1432998 said:Hey guys just talked to Rob. He says he will get it fixed asap. either they send me a new one or i send him mine back and he gets it precisely put on into place.
<3 935 motorsports.
BrandonW;1433003 said:true... hmm i don't know what my old stock set up sounded like because i had a crack in my stock downpipe for a good while lol
supra_guy;1433011 said:gaboon did u make that ddp urself
gaboonviper85;1433009 said:Using a stock elbow is a bad refrence as it has horrid flow...put a normal downpipe on and boost automaticly rises as shit flows tenfold
