Dead/burnt out ECU??
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
Does that ECU have rpm cut like the 7M and most other TCCS do? The symptoms are identical. If so check the TPS to see if the IDL contact is opening when the throttle is opening. If it doesn't it'll do exactly what you're describing. At least the 7M and most Toyotas do.
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
i got a video of it on my phone but its too big to send it to my email
i will get a shorter one and post it tomorrow
OneJSupra
I'm a sleeper ...
Feb 9, 2007
900
Supraland
The Reaper said:
but no sense in replacing the caps if thats not what it is.
just replace the damn caps for $40.00 and if it fixes that problem then you'll home free. If not, at least you took care of the caps problem cuz it will fry eventually.
I put heat sink on my ECU to help cool it a bit. Mini fan is probably the best idea if you could find one to fit inside.
Suprahero...yes bad ecu will get the injectors stucked open resulting in dumping fuel to your crankcase. There was a thread in SF about that just don't know the link.
The Reaper
Jan 10, 2006
1,909
Florida
Ric said:
We drive toyotas. Anything is possible.
i was talking about the above. im not a moron ^^^ THAT is not a serious answer
im at work i can't look at it. it fucked up on my way to work i took it back to the house got my trusty honda and came to work. i haven't had time to look at it when its 30 miles from my work and im at my desk
and i know they said to check the ECU but what i wanna know is how in the fuck does the ECU DIE when the car is just sitting there????? makes no sense.
T701jz
3M ENGINEER - R.&.D
Jul 23, 2005
657
Santa Clarita Ca.
Quick solution.....Ask Tissimo for his ecu to check if the ecu is the real problem....unless Tissimo is using the 2j ecu then never mind.
Noel
csnow
Matthew 6:33
Palm Bay, FL
Electronics typically don't degrade slowly over time, they just die. It is very common for an electrical part to work fine one day and then be dead the next. Happens all the time with computers i.e video cards, memory, cpu's etc. Your 1J ECU is no exception. Sorry to hear about the problem though Josh....
Ken
350
Houston, TX
The Reaper said:
ok a serious answer please.....
Seriously, throw some Ds on that bitch.
haha, all kidding aside, your absolute best bet is to plug in a good known working ecu. my ecu started acting up too. Injectors # 3 and 5 aren't firing. I opened up the ecu and everything looked fine. I'm sending it out tomorrow to get repaired though.
Evilempire1.3JZ-GTE
SF what a waste of supras
Jun 22, 2006
1,382
SoCal
electronics granade it is called "thermal runaway!" it doesnt happen slow! if you dont believe me pull the heat sink off of your cpu on your computer at home on a nice cold or cool day and see how long the cpu last. Ambient temp does not matter.
If you add a fan it will make things worse down the road because it will suck all the dust into your computer then stick in there until a dirty ecu generates even more heat then a clean one because its blanketed in dust sou you need to at least add a filter and clean it at least once every couple months.
The best low maintenence solution is to use heat sinks the one on the back of the old pre 89 supra radios fits perfect!
I have my old ecu for sale but i am going to sell it with 2 feet of wire plus connectors and the jumper harness. selling it because i am just using a stand alone wolf ecu! ill put in fs section soon.
If you decide to replace your ecu which is the easiest thing to do go with arrons driftmotion stinger stand alone setup he is making the adapter harness and is much better then the SARD/MINES/BLITZ ecu because the cost nearly the same as a stand alone which comes with warrenty and could be tuned where with the JDM oem tuned ecus you dont know what the tune is and it might damage your engine because they tune for extremely hi octane gas for daily driven.
The Reaper
Jan 10, 2006
1,909
Florida
awesome. thanks for the replys guys.
ok i took a vid of my car with my phone
keep in mind im holding the throttle at 60% the WHOLE TIME. i'm not letting off or feathering in ANYWAY and this is what its doing. sorry vid is small but you can hear the car and see the tach good enough. the jump in RPMs for a second there was all the car not me
That's gotta suck, but I don't know how to fix it. I'd definately do like everyone else has said, and try to borrow another ecu and see if it fixes it. Good luck.
The Reaper
Jan 10, 2006
1,909
Florida
hahahaha thanks Jay!!! haha yea im gonna borrow a friends but im also afraid that it could be something else that messed mine up and i dont want to end up messing his up
i know the plugs are BLACK
The Reaper
Jan 10, 2006
1,909
Florida
but we're almost thinking its a sensor failure. cause as justin was saying on another board it sounds like the ecu is being put in limp mode, and he thinks the missing is caused by the limp mode.
