Dead/burnt out ECU??
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
alright well the 1J has been doing good.
my MPG went up after i realized i had a lead foot. i got 290 to a tanK!!!! i was happy!
well this weekend it ran flawlessly. went to the track (didn't run it) but did ALOT of highway pulls ran perfect.
dropped Justin's (tissimo) Car jack off at his house and smoked an SRT4 BAD on the way home running good.
i wake up this morning to go to work i decided to take the supe instead of my rust bucket honda daily.
i fired it up idles perfect......get going down the road and it wont rev past 2300 rpm. it revs up and hits 2300 and shuts off then comes back on at 1600 rpm. WTF!?!?!?! so i reset the ecu in a hurry. fire it back up SAMETHING!!!!
so i leave it in neutral and floor it.....it revs to 2300 shuts off and comes back on at 1600 and thats all it does. so i floor it again and this time it revs to 6K and shuts of and the rpms fall as i keep tapping the gas it has no response. it hits 1600 and comes back on.
everytime it hits 2300 theres a loud clicking coming from the ECU area but justin and i are thinking its the BC solenoid for the e-01.......is this a dead ecu or fried caps????
Ric
Setting the standard
Feb 22, 2007
1,432
Central Florida
www.1jzgte.us
ECU is in failsafe mode. I'm not 100% correct on this part, but it does this when one of the cam sensors goes bad.
I had this same thing happen to my beater 1JZ SC when I had that. ECU was crapped. I had a spare to test without doing major diag work.
I have the answer on what sensor makes it do that just in case its not the ECU, gimme a few mins.
Ninja edit:
A bad cam sensor will make it do that also.
The Reaper
Jan 10, 2006
1,909
Florida
yea we're gonna check the Crank position sensor when i get home and all that good stuff.
it makes no sense to me tho how it can run and take a beating perfectly fine ALL day and night on sunday, but then i let it sit over night and a sensor goes bad.
Ric
Feb 22, 2007
1,432
Central Florida
www.1jzgte.us
Sensor or ECU.
If you don't have a CEL, my bet is ECU.
Getting a new input processor chip for the cam sensor from Nippon Denso is pure Unobtainium.
I now use that ECU for a parts bin, just in case my injector drivers or cap's blow on my SARD.
The Reaper
Jan 10, 2006
1,909
Florida
that would suck
i'll be pissed if its the ecu
the car will sit for a very long time as i will be over the damn thing at that point
Ken
350
Houston, TX
The injector caps are the three green blocks on the inside of the ECU right? Would there be any visible signs of damage if they are bad?
OneJSupra
I'm a sleeper ...
Feb 9, 2007
900
Supraland
trials and tribulations on owning a 1J, yours isn't bad considering it ran after the swap.
getting the caps replace will run you around 25-50 dollars, getting a used ecu if you can find one decent with no problems will run around 250-350. i say replace the caps already.
Ric
Feb 22, 2007
1,432
Central Florida
www.1jzgte.us
Could be the caps, its a common issue. Not alot of other things break in there.
Here are the cap value with ebay links. Most come from seller TechnoStar so shipping is cheap. You could always just go somewhere local. We have an industrial warehouse here that sell this stuff locally.
33uf, 35V
http://cgi.ebay.com/Electrolytic-Ca...yZ111603QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
15uf, 35V
http://cgi.ebay.com/Aluminum-Electr...ryZ36336QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
47uf, 63V
http://cgi.ebay.com/Philips-MKT-Cap...oryZ4662QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
220uf, 10V
http://cgi.ebay.com/Nippon-Capacito...oryZ4662QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
100uf, 10V
http://cgi.ebay.com/Miniature-Elect...yZ111603QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
Order em up off the internets and have someone solder them on the board like a TV repair shop. Heck, they might have em in stock there.
That's exactly what I did. I had a tv repair shop do mine. He charged me $40.00 for everything. Good luck.
Offtopic warning: Could a bad ecu cause excessive fuel to be dumped into the crankcase?
The Reaper
Jan 10, 2006
1,909
Florida
but how in the fuck can caps go bad at night when its just sitting in the damn driveway???!?!?!?! it ran PERFECTLY yesterday
i was racing justins 2J car all the way home from the track NO PROBLEMS!!!!
then raced an SRT4 on the way home from his house beat him by like 3 car lengths, then park it for the night and then it just fucks up???? MAKES NO SENSE!!!
The Reaper
Jan 10, 2006
1,909
Florida
yes i was basically saying you were correct joe LOL so dont drop yur head and shake it HAHAHA
yea it was my heavy foot
