ForcedTorque;1248383 said:For my own benefit, and for completeness in this thread, can we have some discussion in here about the proper way to torque this bolt to 195 ft-lbs. Mine broke lose yesterday while trying to break the flywheel bolts lose. The thread scares me of future problems if I don't get it torqued back correctly.
supradjza80;1250697 said:If it were me I would try to torque the bolt with the car over a pit. Put the car in gear (1st/R with a manual) or park with the auto and have the ebrake on and torque the bolt. Should have little issue with that.
I haven't done it before but if I had to that is what I would probably do. Im not sure how easy it is to find axis to a pit, but i know most semi shops have them.
I will probably check the torque on mine for piece of mind.
-Dave
-Dave
black89t;1250754 said:um.......i don't think that would be a good idea. the best gear to put it in is 4th. in any other gear you will be loading all the bearings, the hub and sleeve, plus the gear on the op shaft and couter shaft that your in (hint: rev. has small straight cut gears which wouldn't like that). but in 4th your practically bypassing the tranny as all it does is lock the input shaft to the output shaft. so the only thing getting loaded is the sleeve and hub. just wanted to point that out so nobody hurts their tranny.
supradjza80;1250894 said:You realize your motor out puts much more torque then 195 lb-ft...You will not harm the transmission doing this. The tranny is way more then capable of doing this. The best gears are 1st/R as they make it the hardest for the wheels to turn.
IJ.;1250916 said:Dave: Bzzzz think it over a bit![]()
supradjza80;1251000 said:ooops i lose, yeah go with 4th or 5th gear. I was thinking the gear reductions through backwards. Thats what i get for quick posting while in class...
The tranny will be fine regardless of gear though, the motor can output much higher torque values on it then 195 lb-ft
gaboonviper85;1251156 said:It's not about stress on the trans...you don't want to put it in first gear cause when you start putting pressure on the crank bearings and may put a indent in them...in 4th gear the trans will stop the crank from rotateing which will assist in not putting too much pressure on the internal bearings.
ForcedTorque;1250740 said:Thanks for the info Dave. I am currently in the middle of a clutch job, so the tranny is out right now (motor still in car). I attempted to torque it last night, and got 170 on it while holding a flywheel bolt. My ARP flywheel bolts are in with loctite of some sort on them. I broke the crank bolt loose trying to get the FW bolts off. I have since changed that idea, and am holding the FW with a piece of flat bar. I have 4 more bolts to get off before going back in with the tranny. I'll get the torque wrench back once it is in, and get that other 25 pounds on it as you posted.
Any good ideas how to get those FW bolts off. I need to hold the motor still with something. My flat bar likes to turn up on it;s side, and bend once I get some real pressure on the wrench.
