Costs in 7mgte vs 2jzgte
p5150
ASE and FAA A&P Certified
Central Idaho
*** This is something I took from the other thread where I explain all of my justifications. I dont feel like typing this out again.***
The whole point of what im saying is comparing this to building a 7m with forged internals that is capable of CONSISTENTLY running 500+ hp. If you have a stock setup and dont plan on modifying the 7m block past 450-500 hp then the turboed GE isnt worth your time.
Quote:
Just offhand... let's say you buy your magical 2JZ-GE for $400.
Don't bother doing what anyone with half a brain would do - crack that bitch open and replace *MINIMUM* mains/rods/rings/seals (not to mention measure out all specs)
A $400 dollar 2jzge isnt magical - you obviously havent looked for one very hard.
I did crack it open and measure everything - all components are PERFECTLY in spec and the cross-hatch is still visible on the walls. The motor had 70k miles on it. Why replace it all if there is nothing wrong with it? The rings are already mated to the cylinder walls and have been broken in. If I replaced the rings I would have to re-hone and that would take some material off the wall. Theres nothing wrong with the bearings either. Plus, all of the hardware measured perfectly in spec with the TSRM, and it is reusable.
$90 for a gasket kit
Quote:
I've got an '88 Supra.
Does that 2JZ-GE bolt up to the '88 mounts?
No, but you can buy some BIC motor mounts for $175 or put in an 89 subframe for cheap from a local u-pull-it.
Quote:
How am I mounting my CT26 to the 2JZ?
Well, if you are building a 7M with forged internals then im guessing that you probably arent going to bolt a ct26 back on it. If you AREN'T building a 7m w/forged internals then I guess you wouldn't need the 2j anyway because you have modest HP goals. Its a wash either way because for +500 hp on a 7m you are going to have to purchase an aftermarket turbo and manifold. They are the same cost for both engines....
Quote:
Turbo oiling and coolant?
What about my exhaust?
Turbo oiling supply and drainage can be accomplished from 100-175 bucks for a nice oil line set. Most aftermarket turbos dont come with water coolant but you are going to have to adapt that for the 7m anyway...... So once again, its a wash because unless you are getting some bolt on like a SP61 for the MKIII, you will have to get oil lines ANYWAY.
Quote:
Since I'm turboing a 2JZ, and it has a FFIM, how much is an intercooler?
Intercooler pipes?
Will my stock fuel lines bolt right up?
Throttle cable?
Well, the 2jzge DOESNT HAVE a FFIM. But I thought you would already know that. Regardless, $200 for an ebay intercooler setup IF you decide to go with a custom FFIM, and ffim intercoolers are easier to get than the same-side 7m style. Im not going to consider the cost of the IC or hardpipes because you could easily modify the stock 7M pipes to fit if you wanted to just get the engine running and drivable, and purchasing a set of hardpipes or intercooler, like a single turbo for 500+ hp, is something you would have to purchase for both engines anyway.
As for fuel lines we are, once again, back to the same question. Forged internals on your 7M? Yes? Why are you running a stock fuel system? Upgrades are required for both motors; its a wash.
Throttle cables are cheap and easy to come by. Which one you use would depend on the throttle body.
Quote:
How am I controlling the 2JZ ECM wise?
Im so glad you asked that. Lets get a total cost of what we REALLY need to do a 2JZGE swap with the assumption that we are going 500+ hp BEFORE we purchase our ECU. Items that would be required for the 7M AND 2JZGE for this hp level are not included. They are a wash. Ive added some things that you didnt list:
$400 - Engine
$100 - Gasket Kit
$200 - Thick head gasket
$600 - 1JZ bell housing and flywheel (new)
$200 - for r154 (if you dont have one)
$175 - Motor mounts (IF pre-89)
$1675 - For a 2jz with FORGED PISTONS ***edit - the pistons arent forged they are pressure-cast aluminum just like the 2jzgtte****, STRONGER RODS, 1.5mm BIGGER VALVES and no oiling problems. Just look at the internals of a 2jz; it is a better-engineered engine.
$1400 for an AEM
$250 for a wideband O2
Now we are at $2950 to $3325 depending on if you have an R154 or a pre-89
Thats one of my points -
Quote:
Let me put it this way - if it were that easy for the AVERAGE JOE, we'd be seeing a hell of a lot more JZ MKIIIs.
Well, most people on here arent "average joe" - they are very mechanically inclined. I assume that you are one of the more mechanically capable people because you are arguing with me about it. Am I wrong?
Quote:
For the price of "properly" dropping a 2JZ into my MKIII, I'd have a... well, I'd damn near have Duane's 7M
BTW -
$1000 in machine work
$350 for forged pistons (Probe)
$100 for rings
$120 for MHG
$100 for ARP head studs
$100 for Clevite 77 Mains/Rods
$500 for Rods and rod bolts
$100 for gaskets
$100 for Main Studs
$150 for an oil pump
$100 for Oil Thermostat or adapter and lines
About $2k ***EDIT by p5150 a VERY CONSERVATIVE $2720*** for a bulletproof 7M? What am I missing here
Uhm you are missing connecting rods, main studs, an oil pump and a gasket kit : but I added it for you. That will run you an additional $800 combined. And your head STILL wont flow as much so you better dump another $1k on it (minimum) for port and valve work, but I guess that isnt REQUIRED to get to the 500hp mark - it only makes it easier - so we wont count the $1k.
If anybody wants to argue about flow numbers look here:
Post 28 - http://www.supraforums.com/forum/sho...#post214624 6
Post 19 - http://www.supraforums.com/forum/sho...ght=2jzge+flow
So when it comes down to it, we have a (more capable - dont forget that we didnt change the valves in the 7m yet) 600+ hp engine with an AEM for ~600 more than just the cost of building a 7MGTE.
Plus, if something happens with your support equipment that ruins your block (lean condition from FPR fail/ fuel injector fail/ poor tuning/ clogged fuel filter or injector/ running through a puddle of water and hydrolocking your engine (malloynx)/ over-revving on a patch of ice(figgie)/ over boosting due to a kinked wastegate line(a friend I know here in town)/ etc etc and I have seen or heard of all these things!!!!) you have a VERY CHEAP CORE SOURCE that you can drop in the car with a HEAD GASKET CHANGE.
Sure, this isnt worth it for everyone - but for those that say "500-600 hp is my goal", they would get there a lot faster for less money with more reliability if they would just go 2JZGE(T).
p5150
Central Idaho
drumminforev said:
Ok so it looks like 7m is capable of 400whp with stock internals... whatis the limit of these stock internals now.
And for you
Try making that say
2JZGE engine (harness and ecu included) - $500
Full Turbo kit - $1000
No rebuild needed (since lots of people believe it is bullet proof)
1J tranny bell housing - $200
MISC - $1000
thicker hg - $250
spare mk4 auto tranny for sale - NEGATIVE ($200?)
Total = $3050
Which is cheaper and more powerful now?
Well - if you are going 2j na-T, I assume you want some big power. You can run a 2jzge at 600+ reliably.
The 1000 for the turbo kit is a wash - you will spend that for a 7m also.... Support stuff (injectors, turbo, exhaust, manifold, etc) is going to be the same for both motors. The point is that its less expensive and more reliable to swap in a 2jzge and turbocharge it because you get a motor with a bottom end that is practically the same as the turbo engine.
You obviously didnt read the links to the threads I posted.:naughty:
p5150
Central Idaho
gilberjj said:
haha, this is hilarious...... some of you guys get so worked up over stuff thats been covered a million times. maybe when i have 1000+ posts ill be a groucy veteran too. who knows. as for this thread, if you are planning on doing a swap yet you don't really know much about either engine, im seriously doubting that you have the knowledge and mechanical experience to do either swap and all the work yourself. i would love to see you prove me wrong though. as for all of these crazy high expensive estimates, it can be done for cheaper. look at this link
http://www.7mpower.com/john_lunsford.shtml
thats well over 400whp AND hes useing a stock intercooler AND stock injectors. you clearly haven't done much research, but whatever, if ppl don't want to post they don't have to. but seriously, i don't think it is very cost effective to put a 2j in a mkII when a 7m bolts up easy and stuff is cheaper for the 7m. but if you think the 2j is cheap, then just for for a tt v8 swap hahaha. check out this thread......
http://supraforums.com/forum/showthread.php?t=388456
EVERYBODY CHECK OUT THIS THREAD ^^^^^
Sorry bro - I disagree with you. I think the turbo STOCK w/HG 2jzge is a much more cost-effective route than building a 7m for high HP. If you plan on staying around 4-500 then the stock block 7m is a good choice, but anything higher, IMO, is a waste of money when rebuilding the 7M with upgraded internals.
Look at xman though - he is making 600+ on a blueprinted stock 7M. He is a good example of proper tuning and certainly one of the higher HP RELIABLE stock internal 7Ms ive seen posted up. He did have his motor blueprinted though - it wasnt just a used block that he threw in.
kwnate
Lurker
Jul 10, 2005
2,725
None of your fucking business
So basically the 2jz-ge-t is good for people that want to half ass it?
p5150
Central Idaho
No - no disrespect to you man - you have done a good job putting your car together.
The point is that the 2JZGE is damn near the same thing as the 2JZGTE and it is INEXPENSIVE. If going big single it is a very cost-effective option.
D
drumminforev
Guest
Hey p5150 do you have any links to info on proper sizing of the hg replacement.
are you saying you did not replace mains rods rings. Which specs are you measuring...
p5150
Central Idaho
EDITED FOR ACCURACY ON 20060122 DUE TO MORE ACCURATE MEASUREMENTS
The time has come for me to purchase a head gasket to lower my C/R.
For all of your sakes I have taken measurements of all aspects of the engine and included already known specs. The block has been re-surfaced and so has the head.
These measurements are very accurate - I used a graduated cylinder, syringe and measured/remeasured several times. Volume measurements were very consistent. The piston dish volume was measured with the piston installed in the block. It is nearly impossible to accurately measure the piston dish without it being installed.
Piston dish volume (including area around rings) - 9cc
Piston deck height - approx .006 inches (this can vary depending on how much you have removed for resurfacing)
Combustion chamber volume - 46cc
Bore - 3.386 inches (86mm)
Stroke - 3.386 inches (86mm)
Head gasket bore diameter - 3.425 (for an 87mm Cometic)
Gasket thickness - xxxxxxxxxx
Now plug it into something like this and be sure to put the (-) signs where they belong for the Java app:
http://www.csgnetwork.com/compcalc.html
WITH AN 87MM BORE HEAD GASKET, THE HEAD GASKET THICKNESSESS (IN INCHES) BELOW WILL YIELD THE FOLLOWING COMPRESSION RATIOS:
.228mm/.009" = 10:1 (approximate stock HG thickness)
2mm/.079" HG = 8.57:1
3mm/0.118" HG = 7.94:1
D
drumminforev
Guest
What exactly is the point of measuring the piston dish volume, deck height, and combustion chamber volume
How do/did you check for out of round bore?
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
Cool, so I'm a "half-ass"er for trying something different. Instead of people saying "okay, cool.. I hope it works. It's nice to have a cheap, reliable, and different option.. if your built goes as planned", we get shit.
Maybe we dont have a huge ammount of income.
Look at it this way..
2JZGE- 650 shipped
Manifold, dp, inlet tube- 200
1zj bellhousing- 300
bic motormounts- 175
flywheel- 275
Turbo- 598
Turbo lines- 125
HG- 198
oil return flange- 32
FMIC- 150
So I've sold
7M- 1000
FMIC- 280
Turbo- 800
Manifold- 250
(much more to sell/sold)
After all that.. my balance comes out to under $400... thats way less than ONE HG job on a 7M! So why can't people just be open?
8,898
MRSUPRA said:
Actually the head design in the 2JZ is not that great also. Most heads from Honda, Nissan, and Mitsubishi are much higher flowing than the 2JZ head.
A Camry head out flows the all conquering 2JZ head, according to the flowbench in link provided. :wuteva:
89_turborunner
57
Oregon
p5150 said:
I assume that you are going to hone the cylinders then? My 7M cylinder walls were in excellent condition still on my 200k 7M. Cross hatch was still visible.
That rebuild does sound relatively inexpensive, and a little bit closer to what I would expect to pay if everything was OK with the internals.
I opted out of the 7M block though - I think the 2jzge-t is a better option unless you already have a 7M setup (manifold etc.)
No hone. Cross hatch looked good. So are you saying you still honed?
Oh and add $1.40 for plstigage, lol
87CandyBlueT
553
Kentucky (NKY)
drumminforev said:
Well dark, you can tell me to search all you want but if i dont find an answer then im going to post a topic. Its as simple as that. Now i did not see any thread in here that says "7mgte vs 2jzgte cost comparison"
Anyway.
"Stage 7:
Fuel tuning device and dyno tuning, 375bhp @ 16psi '
Ok, thats just about a fully built 7m. And im talking about more than 375whp So it would be:
intercooler upgrade
pretty much maxxed out turbo, time for an upgrade
p&p, valve job, balance etc machine work
radiator
manifolds
mhg
springs, retainers
fuel injectors, pump
oil, accusump, etc
ems
tuned
r154
clutch and PP and flywheel
internals.
How is that a stock not fully built, please tell me. I would not run stock pistons and rods and run 400whp
LOL I'm not going past the first page of this... You need to research and then ask questions.
suprafreak123
179
Costa mesa
I Wish i had all the money in the world i would slap and 2jz.I just love the sound it makes when driving through town.I think every engine is capable of handling power due to some owners who are like females.Some owners turn key, drive off, engine blows, bad engine then they spread the word of it being bad.If the owner would take 5 minutes while the car is warming up to check fluid,hoses ,belts cars would last longer.
