Figit090 said:for one, fix your timing
two, dont just cut off your cat...if its bad you shouldnt sell it, if its good, you want it. i guess its up to you, but your car will pollute a lot more without it. not good at this point in time. and i dont think its smart. if you are worried its clogged you can remove your exhaust and take a quick test drive (loud!! and dont let it get hot or sit idling with you in the car!!!) or cut it off and replace it with your choice of exhaust pieces.
you shouldn't be smelling gas. its possible you have a leaky fuel system or injector... if its excessively rich or your timing is way off i guess that could do it, but just fix your timing. having you car tuned funny to start will just make everything else harder and you dont want the extra varaible - bring it to stock.
if you decide to drive her more, look underneath at the cat and see if its too hot, if its clogged there's a chance it will be RED hot. DO NOT touch it, but if its excessively hot you might be able to tell and that will give away if its clogged. otherwise i dont know how you can outwardly tell if its gone bad.
if your car cuts out at 3500-4k like you said when you rev it, it will not run right when you're flooring it under a load. until you get the engine running right you wont know if its the clutch or an engine issue. again, timing might effect this. so fix it. if your plenum clicks to full-bore under full-throttle, you'll feel more power, and then if your engine gets starved or starts getting to far out of time/rich, you will start having problems. the car does react differently under full-throttle, and the HP curve might just be at around 3.5K RPM... not sure. if you want to hear proof that your intake changes, turn the key on (not the engine) and depress the throttle. nearing full-throttle you'll hear a click when the plenum valve moves.
as for your AFM - you should look at a stock one before deciding that is has been modified. clear silicone? i'm not sure if that isn't stock. mine is silicone-sealed and if its been tampered with i will be suprised. and worried. but either way. find one you know is stock. unless its a mess, yours might be. and i think there is a test you can do on at AFM to see if its still good. but you could just swap it permanently or temporarily to see the effects. hopefully the new part is a good one though.
You give a lot of great information, :aigo:
I know its been messed with, the silicone is messy and I looked at a stock one, and it looked.. stock? haha, mine has been tampered with.
Never thought to check the cat once i got it warmed up and ran it a bit, will do soon. Also, that is my plan. I'm going to cut it off and weld a straight pipe in.
If I fully put my foot in it, the engine sounds a tad weird past 4k, and I know its probably because of insane backpressure.
I raced my friends single cam, 2 valve, 4 cylinder friggin jeep with a manual and lost, so something is wrong with my car
I will knick that AFM, put it on, and then figure out how to advance timing, and try to check my timing on mine. God I know all this stuff for a DSM, just not a Supra, ugh lol
Edit: Its probably rich, because a common mod is to pop that cover off and click it a few clicks to make it run slightly richer and improve performance, but they prolly fucked it up, lol (at least thats what my friend told me)
