jetjock said:Good. I could use some entertainment.
2nd'ed!!
btw
I run electric fans.. no not the lame-o dual 12 incher barely blow a leaf anywhere slim line crap. The dual 13 inch sucker is what i use. Plenty of room between the frame
Poodles said:he's N/A, so you can run that timing, on a turbo motor you're just wishing for a dead engine...
E-fans are FINE, as long as you don't skimp out on them. They'll cool better in stop and go traffic because it's not RPM dependant.
If NOT wired properly, and not sized right or using crappy fans, they're just gonna leave you stranded...
phoenix6 said:Eh, well my shroud is also gone, didnt affect anything but its gone haha.
OneJoeZee said:The fan shroud is an integral part of the cooling system..
IJ. said:Try driving it on the hottest summer day in traffic with the aircon on and see how it fares![]()
dbsupra90 said:just thought id note- the stock temp gauge is real inaccurate.
yeah, you will know if it has a serious problem, but other than that its far from being realiable. my aftermarket gauge can swing 40 degrees before the stock one thinks about moving.
starscream5000 said:Cheap fix and you'll never have to worry about for another 15 years.
Fan shroud... ~45.00.
10 blade fan... ~??.?? check.
Re build fan clutch... ~10.00 yep, check.
Making sure you have the engine undertray... priceless.
starscream5000 said:but you may if you drive at high RPMs for an extended amount of time.
