Even if I have like 4000 miles on he rebuild and the reason it leaks is due to a mhg that was sprayed with permatex and reused??
If you take it in to M&B Cylinder Heads, on Vancouver Way in North Portland, just off the I-5 freeway, you can use my torque plate, for no charge, (I usually charge $200 security deposit), and have Brian at M&B torque plate your block and bore six perfect cylinders. They build wicked Supra motors. Give Brian a call: 503-286-1725. Check out their web page: M&B Cylinder Headsjdmfreak;1729450 said:Well thanks for saving me from another headachelooks like I am gonna have to buy a clutch for my dd cause the supra will be down a while longer :/ oh well gotta do it right ..... hey do you guys know of any good supra machine shops in vancouver or portland???
Sent from my DROIDX using Tapatalk
syty1;1728288 said:Nobody has mentioned mirror-finish on the block and head for a MHG. If it's not mirror finish....it Will leak - garoonnnteeed
mkiiichip;1813714 said:^Then why is there a valve, to shut off coolant flow to the heater core, when its not needed? Just sayin.....
nrdriver;1813685 said:just puttin in my two cents. in my experience. no heater and overheating because of a blockage is caused be a clogged heater core. the core doesnt get hot so you have no hot air for the heater. with the heater core being blocked your coolant isnt circulating.
only been a mechanic for ten years lol
